Page 1 of 2
Mods
Posted: Mon Aug 01, 2011 10:56 am
by tshodges
I've created an updated post. Please check out: "Connecting the Lar/Mar in a Bugera 1960"
Mods
Posted: Wed Aug 03, 2011 9:29 pm
by tshodges
I've created an updated topic. Please check out: "Connecting the Lar/Mar in a Bugera 1960"
Re: Installing the Lar/Mar PPMIV in a Bugera 1960
Posted: Wed Aug 03, 2011 10:40 pm
by OnTheFritz
Maybe post a pic of the innards, and people can help you from there. From my understanding, there's ribbon cables etc, like a PC, so a picture is worth a thousand words.
Mods
Posted: Thu Aug 04, 2011 2:19 pm
by tshodges
Mods
Posted: Mon Aug 08, 2011 1:36 pm
by tshodges
Posted: Mon Aug 08, 2011 2:52 pm
Sorry cannot find a schematic or parts layout for one of these.
Need to locate the phase inverter caps and the grid resistors for them (and the resistor values) , once you do that need to decide where the pot can go.
What features does the amp have now - no MV?
Mods
Posted: Tue Aug 09, 2011 12:56 am
by tshodges
Mods
Posted: Tue Aug 09, 2011 1:18 am
by tshodges
Posted: Tue Aug 09, 2011 5:17 am
I am pretty familiar with the 1959 schematics over the years
It is difficult to see what part is located where on those pcbs.
I can make out the preamp section with the board mounted B9 sockets. The one nearest the switches will probably be the phase inverter. You are looking for the PI out grid resistors (usually 220k on an NMV Marshall with EL34s) these can be 82k to 220k depending on the output valves being used. A close up photograph of that part of the preamp pcb might help so that I can see the components, their values and where the traces go, not easy from the pics we have so far.
Mods
Posted: Tue Aug 09, 2011 2:18 pm
by tshodges
Mods
Posted: Wed Aug 17, 2011 9:07 pm
by tshodges
Posted: Wed Aug 17, 2011 10:15 pm
by toner
It's impossible to tell how to add the MV from those pictures. You really need a schematic or take it to a local tech.
I'm pretty sure the PI socket is the one on the right labeled "V5" so the connections of interest should be around there. There's a good chance that the PI output caps and the bias feed resistors are not directly next to each other on the PCB. You'd likely have to do some continuity and voltage tests to locate them without a schematic.
Posted: Fri Aug 19, 2011 7:35 am
by robert
Simply find a serious & good tech, get the layout & the schematic from Bugera or their distributor, and voila!
Because it's a very simple amp with absolutely no secrets inside, and since Bugera claims to be a professional manufacturer, there should be no problem to get the layout and the schematic.
Regards
Robert
Mods
Posted: Wed Aug 24, 2011 12:34 am
by tshodges
Posted: Tue Aug 30, 2011 2:16 pm
It would be easy to talk you through it with a schematic
