I picked up a circa 1975/76 2187 50-watt 4-input combo (2-12" combo version of the 1987 circuit head). These combos are mounted in the cabinet like a VOX combo and REALLY suffer from the retained heat. This was causing the Marshall ST1 (iss.202) printed circuit board to lift traces and exhibit some rather strange sonic symptoms at operating temperature and volume -- the vibrations just caused several bizarre things to happen. Hard to diagnose until the board was actually removed.
Seems like my best choice is to replace this damaged board with one of George's boards and opt to change the circuit to the 2100 Lead And Bass circuit while I'm at it.
As I understand it, the 50-watt 2100 Lead & Bass combo is the same as the
1964 Lead & Bass head, so I found a schematic for the Marshall 1964 and sent it to George. He's working on that replacement board now and I'll keep up on this project and results here.
Of course, I'd really appreciate any input on my thinking here as I could be COMPLETELY WRONG about the circuit being exactly the same as the 1964 head circuit. But on the bright side, it's a Marshall circuit and all the differences seem to be so minimal that a second visit to modify the new MetroAmp circuit board should be a breeze (unlike that old pig Marshall pc board!). Anybody have an schematic from Marshall specifically for the 2100 combo model? I'd love to hear about it!
Perhaps George might speak to the circuit differences either coming from the 1986 Bass circuit and from the 1987 Lead circuit -- or BOTH. Cool!
Also -- If you see and posts on other boards concerning these "Lead & Bass" models, please direct the posted here or add a heads-up to this post.
-- Sonar
