paul gilbert modded marshall
Jeremy1283
Post by Jeremy1283 » Wed Aug 06, 2014 8:19 pm
He is a Paul Gilbert modded marshall I took photos of awhile ago.. thought you guys would like the pics
http://s1295.photobucket.com/user/jerem ... 1.jpg.html
white noise
Re: paul gilbert modded marshall
Post by white noise » Wed Aug 06, 2014 9:09 pm
Kinda looks like Lee Jackson's work.
Jeremy1283
Post by Jeremy1283 » Wed Aug 06, 2014 9:18 pm
Im just learning so it all looks the same to me. Lol
Haze13
Post by Haze13 » Fri Aug 08, 2014 3:34 am
This silicon reminds me of CARR amps... Every part there is just coated with silicon!
Jeremy1283
Post by Jeremy1283 » Sat Aug 09, 2014 12:40 pm
I know. Why do they use so much silicon? :scratch:
rgorke
Post by rgorke » Tue Aug 12, 2014 4:23 pm
white noise wrote:Kinda looks like Lee Jackson's work.
I am pretty sure Lee Jackson did some, if not all of the work on Paul's amps back in the '80s. I use to work with Lee's girlfriend at the time.
Haze13
Post by Haze13 » Wed Aug 13, 2014 5:52 am
I see only 3 preamp tubes. One of them must be PI, so it's a 3-gain stage amp with CF+tone stack... Kind of JCM 800 with more gain.
Jeremy1283, I think CARR uses that much silicon because it's holds the parts together + if some part will touch another part it will not conduct. For true point to point wiring I look at "BC Audio" or Audio amps like Jadis. It's an ART to wire them like these guys do...
Jeremy1283
Post by Jeremy1283 » Wed Aug 13, 2014 3:36 pm
Haze13 wrote:I see only 3 preamp tubes. One of them must be PI, so it's a 3-gain stage amp with CF+tone stack... Kind of JCM 800 with more gain.
What does a cf tone stack mean? Just the type of resistors.
I dont see that glue in any othet amps.. Well I'm learning. Thanks for the input.
Haze13
Post by Haze13 » Fri Aug 15, 2014 10:34 am
CF - Cathode follower. In the Marshall schematics (Plexi, JCM800, JTM45 and others) it's what comes before the tone controls. Vb2 is the Cathode Follower.
SteadyEddie
Post by SteadyEddie » Fri Aug 15, 2014 2:02 pm
Haze13 wrote:CF - Cathode follower. In the Marshall schematics (Plexi, JCM800, JTM45 and others) it's what comes before the tone controls. Vb2 is the Cathode Follower.
Yeah, a cathode follower has no voltage gain, it doesn't boost, but it changes the output impedance to better drive the tone stack.
Some people mod the CF to a gain stage, to add gain to the amp. There are people who like and dislike this approach.
Jeremy1283
Post by Jeremy1283 » Fri Aug 15, 2014 2:18 pm
I gorcha! Do you loose the plexi tone if you make it a gain stage. Any time i change my 12 series to a 2203 preamp with a master volume it looses that plexi sound. Weird
SteadyEddie
Post by SteadyEddie » Fri Aug 15, 2014 3:19 pm
I never tried the mod. Some hot-rodded plexi-type amps like Splawn and so on (If I'm not mistaken) do this. I'm sure some people will say yes, and some people say no.
Jeremy1283
Post by Jeremy1283 » Mon Aug 18, 2014 2:03 am
Its a matter of taste.
RACKSYSTEMS
Post by RACKSYSTEMS » Mon Aug 18, 2014 10:56 am
Yeah this is for sure a Jackson mod.
Rack Systems / Tone Merchants
5419 Cleon Ave.
North Hollywood, Ca. 91601
[818] 209-4309
Racksystems@yahoo.com
Tonemerchants.com
joey
Post by joey » Thu Aug 21, 2014 11:32 pm
That amp has 4 preamp valves, the fourth is obscured by all the floating components and is between the 2nd and third preamp tube.
The circuit is mostly his m1000 circuit, but has his attenuator circuit as well which is basically another form of ppmiv. (Found on the later ampeg amps)
