Page 1 of 2
paul gilbert modded marshall
Posted: Wed Aug 06, 2014 8:19 pm
by Jeremy1283
He is a Paul Gilbert modded marshall I took photos of awhile ago.. thought you guys would like the pics
http://s1295.photobucket.com/user/jerem ... 1.jpg.html
Re: paul gilbert modded marshall
Posted: Wed Aug 06, 2014 9:09 pm
by white noise
Kinda looks like Lee Jackson's work.
Posted: Wed Aug 06, 2014 9:18 pm
by Jeremy1283
Im just learning so it all looks the same to me. Lol
Posted: Fri Aug 08, 2014 3:34 am
by Haze13
This silicon reminds me of CARR amps... Every part there is just coated with silicon!
Posted: Sat Aug 09, 2014 12:40 pm
by Jeremy1283
I know. Why do they use so much silicon? :scratch:
Posted: Tue Aug 12, 2014 4:23 pm
by rgorke
white noise wrote:Kinda looks like Lee Jackson's work.
I am pretty sure Lee Jackson did some, if not all of the work on Paul's amps back in the '80s. I use to work with Lee's girlfriend at the time.
Posted: Wed Aug 13, 2014 5:52 am
by Haze13
I see only 3 preamp tubes. One of them must be PI, so it's a 3-gain stage amp with CF+tone stack... Kind of JCM 800 with more gain.
Jeremy1283, I think CARR uses that much silicon because it's holds the parts together + if some part will touch another part it will not conduct. For true point to point wiring I look at "BC Audio" or Audio amps like Jadis. It's an ART to wire them like these guys do...
Posted: Wed Aug 13, 2014 3:36 pm
by Jeremy1283
Haze13 wrote:I see only 3 preamp tubes. One of them must be PI, so it's a 3-gain stage amp with CF+tone stack... Kind of JCM 800 with more gain.
What does a cf tone stack mean? Just the type of resistors.
I dont see that glue in any othet amps.. Well I'm learning. Thanks for the input.
Posted: Fri Aug 15, 2014 10:34 am
by Haze13
CF - Cathode follower. In the Marshall schematics (Plexi, JCM800, JTM45 and others) it's what comes before the tone controls. Vb2 is the Cathode Follower.
Posted: Fri Aug 15, 2014 2:02 pm
by SteadyEddie
Haze13 wrote:CF - Cathode follower. In the Marshall schematics (Plexi, JCM800, JTM45 and others) it's what comes before the tone controls. Vb2 is the Cathode Follower.
Yeah, a cathode follower has no voltage gain, it doesn't boost, but it changes the output impedance to better drive the tone stack.
Some people mod the CF to a gain stage, to add gain to the amp. There are people who like and dislike this approach.
Posted: Fri Aug 15, 2014 2:18 pm
by Jeremy1283
I gorcha! Do you loose the plexi tone if you make it a gain stage. Any time i change my 12 series to a 2203 preamp with a master volume it looses that plexi sound. Weird
Posted: Fri Aug 15, 2014 3:19 pm
by SteadyEddie
I never tried the mod. Some hot-rodded plexi-type amps like Splawn and so on (If I'm not mistaken) do this. I'm sure some people will say yes, and some people say no.
Posted: Mon Aug 18, 2014 2:03 am
by Jeremy1283
Its a matter of taste.
Posted: Mon Aug 18, 2014 10:56 am
by RACKSYSTEMS
Yeah this is for sure a Jackson mod.
Posted: Thu Aug 21, 2014 11:32 pm
by joey
That amp has 4 preamp valves, the fourth is obscured by all the floating components and is between the 2nd and third preamp tube.
The circuit is mostly his m1000 circuit, but has his attenuator circuit as well which is basically another form of ppmiv. (Found on the later ampeg amps)
