The toggle switch ring came off the standby switch on my 1974x amp and I've not had luck finding an exact replacement. Would anyone know if this is a unique part to this amp or how I can find one? See pict below for reference. I've been able to find smooth ones with the slots on top that are NOT knurled on the edge, but not with the notches AND knurled. A bit maddening actually. I suppose I can replace both with matching smooth ones, but I'd like to exhaust all options first for the original part. Thanks the help!
http://i126.photobucket.com/albums/p113 ... exBolt.jpg
Elusive knurled toggle switch ring for 1974x
Re: Elusive knurled toggle switch ring for 1974x
Heard from Marshall UK today. Turns out it IS a rare nut, but available by special order through Tubesandmore.com (mucho kudos to them for being the only company to have followed through with me successfully on this seemingly insignificant part).
This item is #M-NUTS-00022 and would have to be special ordered from the UK.
Arrived today by obviously very slow boat... ha! Thanks to Antique Electronic Supply for great customer service to locate and order this part.
Glad that you found what you needed! Tubesandmore is one of the few places I have found that will special order items from Marshall and other manufacturers.
