Outside Copper Shielding On Transformer
echoplexi1974
Post by echoplexi1974 » Fri Feb 27, 2015 10:11 pm
Hi guys,
I am installing a T2562 power transformer. Does the copper shield on the outside need to be grounded? I'm guessing it wouldn't hurt correct?
Re: Outside Copper Shielding On Transformer
Post by neikeel » Sat Feb 28, 2015 8:03 am
It gets grounded when you clamp it onto the chassis. It is just a type of screen around the gaps between lams and coils that can make odd extraneous fields around the transformer.
echoplexi1974
Post by echoplexi1974 » Sat Feb 28, 2015 11:03 am
Thanks Neil!
Post by neikeel » Sat Feb 28, 2015 1:50 pm
No probs.
I forgot to mention its called a Q-band if you want to read up!
echoplexi1974
Post by echoplexi1974 » Sat Feb 28, 2015 11:17 pm
One of the paper insulators on the transformer screws got a little mangled during the installation. How crucial are those to stay in place? I did a continuity check and the chassis is beeping out to the bell and laminations. Is that OK?
Post by neikeel » Sun Mar 01, 2015 9:18 am
echoplexi1974 wrote:One of the paper insulators on the transformer screws got a little mangled during the installation. How crucial are those to stay in place? I did a continuity check and the chassis is beeping out to the bell and laminations. Is that OK?
I ditch them all as I use original sized 2 bolt fixing not the 4 corner ones, not sure what they are for really!
