Red/brown Phenolic Turret Boards
Does anyone know of a source for the correct color red/brown phenolic boards for a 69 metro kit?
I emailed Brian but I see he is no longer in business.
I also ordered one from watts tube audio but it's a lighter color brown and a good bit shorter that my metro red swirl.
Reason being is I scored a full compliment of Iskras recently and would reall like the board for the correct look.
- Supporting Advertiser
Re: Red/brown Phenolic Turret Boards
We can make these with the double turrets or the Metro-style long eyelets:
- axeman
Like this?
- 67 Marshall Plexi.JPG (128.99 KiB) Viewed 2369 times
Yes, that would be what I am looking for. Stuff seems hard to find even if you want to cut it yourself. Only two possible resources that might seem plausible are modulus amplification int he UK and ******.
Problem is, it needs to be the same as the Metro Kit board, which I have found is a little bit different dimensions. So I'd either need to find a blank sheet and make it myself or if there is someone out there who does what Brian used to.
To further clarify, looking to make the same board that Valvestorm posted, but in the color and type of material that Axeman just posted.
I ended up going with the valve storm double turret board. At the end of the day, it will just be easier that way and I know it will fit the chassis exactly the way it should. Thanks for the replies though.
For future reference: Watts tube audio has a steel perforation drilling template that I've used to make my own turret boards. They have turret staking tools as well. It is pretty easy to do.
The Modulus boards are a good fit for the Valve Storm chassis. I find that I have to trim about 2mil from one end of the board to make it fit. Other than that the boards fit well and look great. All the holes line up fine.
The boards that I buy have the standard posts. I do see on the Modulus web site that you can buy split posts and fit them yourself.
I have used Modulus boards on Valve Storm chassis on all of my builds. I have never had a problem with fit or finish.
Modulus boards are great. Axeman kindly sold some board material here which I bought enough for 4-5 boards using the Watts template and staking tool. I did score an original RS board with RS turrets for too much money but I just had to have it. Haven't seen anything as good as Brian's boards in a while. Event the pro builders I know who use the stuff have limited quantities and have to hunt for more via UK vendors when they run out...when they find a color they like they buy as much as they can. You have to be careful the material is rated for enough voltage, otherwise it will conduct and create noise.
I think sometimes the mystique of the various parts and pieces for Plexi amps is what makes them so entertaining to build. I built a pretty accurate 5E3 two years ago and with the exception of Astron caps, it was really easy to track down all the correct components to get accurate, even a real Jensen P12Q. My Plexi, which started as a kit from George, has been a 9 year journey of always making it more accurate and better sounding. I recently aquired a '73 Deluxe Reverb that I thought would keep me busy, but when I opened it, it was perfectly maintained. No fun there, but can't say I wasn't pleased as it sounds great. And whoever had it before me put a sticker on the inside stating "Punching bad tone in the dick since 1979." Has Richard Smith stamped on it too, so I guess maybe he's the sticker guy. Thanks for the input on boards.
