NFB 69 spec 100 watt plexi
dan_tramble
Post by dan_tramble » Sat Sep 17, 2016 6:46 pm
I am trying to calculate the best NFB for my NMV 1959 build
I see 8 ohm tap 47k was more common. I am using EL34 tubes
Would the 4 ohm and 100k give me more dirt?
Thanks in advance.
Dan
MetroAmp addict!
JTM 50/45,1987's & 1986
1959 and 2203/2204 Amps
1974 amp
Can't stop building, very addictive!
Tazin
Re: NFB 69 spec 100 watt plexi
Post by Tazin » Sun Sep 18, 2016 10:16 am
Ninety-nine percent of the 1969 through 1970 100w Super Lead amps had a 47K from the speaker output jacks as a NFB setup. In 1971 you start to see some variance in the NFB setup for the Super Lead's (i.e. 47K from 8ohm tap). As '71 progresses you see the 47K/4ohm arrangement and then eventually the 100K/4ohm setup comes into play late in 1971.
