Interesting to see a fellow Norwegian in here
I have been on a similar quest with my 1981 JCM800 2204, started out with a 0.68uf bypass cap on the 820R V2 cathode and that was a significant improvement! Still, I feel the low end is a bit... not sure if I would say flubby, 'vintage' is the most accurate word in my head, and a bit uncontrolled. Yesterday I bypassed the 10k V1 cathode with a 4.7k and 0.68uf (3.2k ish total resistance), and it turned the amp into a total gain monster... Although it was too much, I still don't think it sounded overly compressed for the amount of gain it was putting out, which some people who did that modification have stated. People who say anything lower than 4.7k is madness, are probably right. Putting a >10k resistor and possibly a cap on a push pull would be a great way to add a switchable gain boost though, might just do that!
Regarding the fixed resonance mod, I am very very eager to try that but there's a few things I'm uncertain of that could potentially make the modification easier. Is 47k on the 8 ohm tap, equal to 100k on the 4 ohm tap? Or is it the other way around? On second thought, just sticking with 4 ohm would probably be easier so I can just go with the 220k and 0.0047uf values.
Also, has anyone tried to change the presence cap to 0.68uf? Slash's modified amps usually sport this, apparently mainly to reduce squealing but it has to alter the tone somehow as well?
EDIT: didn't see the date of the OP... Oh well
