Hi,
I am new to this excellent forum.
I would like to convert on side of my 9100 power amp to run on el34's. That would give me the choice of using either 5881's or el34's.
I understand that the transformers are fine but that some resistor changes and a re-bias will be needed. I also plan to modify the tray so that the taller el34's will fit under the hood...
Has anybody here carried out this conversion and if so, what steps are needed? I do have the Marshall schematics so no problem referring to the schematic part numbers.
Kind wishes and many thanks in advance...
9100 convert to el34's from 5881
Re: 9100 convert to el34's from 5881
Hey!
I'm currently thinking of doing the same. Did you mod it?
Kennet
Kennet
Kennet Iversen
