back in 2013 I started a 2203 build with intention to later mod it to #34, the build was successful, mod was set in place. Later I added PPIMV. I played some gigs with the amp and it was totally okay. In 2016 I modded it with additional gain stage and the overall switchable config looks like this: #34/#36/Hot-rodded 800 - the changes are done only on preamp. Recently as I returned home I fired the JCM up, and what I heard first was some quiet windy-like sounds coming out from the cab - caps charging up after long time I reckoned. But suddenly amp popped very loudly and I quickly powered it off. Later as I procedeed to fix the amplifier, it continued to do these pops and it fried one of the tubes (measuring voltages I spotted one pair of EL34s was drawing very big bias current). I swapped the pair and I played on the amp for about 2 days - it started to pop again. Then I pulled out the turret board, cleaned it and replaced all parts with the new ones - amp pops again. After this try I rewired power supply section (with caps included) and put new sockets for the power tubes - I played it two times for like 30 minutes, and today I fired it up again - well, you guessed it, it fuc**ng pops again
So I already rewired entire amp, the only thing left to try is capacitors. I am not sure though if I should replace all caps or try to search somehow for the faulty one. The thing that gives me doubts is that sometimes amp plays totally okay, other time I turn it on and after switching standby to on, it starts popping or to these windy sounds. My guess is one cap is shortening the circuit when voltage is turned on. When I rewired the caps I tested them all by measuring resistance - usually when cap is okay, then when you measure it resistance firstly raises and then drops - all capacitors were following that pattern.
What do you think guys? Did anyone maybe had similiar issues and cares to elaborate? I am really running out of ideas
