Just got these in! Designed by George at Metro amp based on an original 69 chassis with Lay down PT.
Holes for (4) preamp tubes.
Suitable for Super Leads, Super Trems, all mannerism of Sl@sh amps, or with blank fronts for you own designs!
Pre-drilled for the Metro (SDM) Zero-Loss FX loop.
Steel with welded (not folded) corners. Zinc Chromate plated.
Click on the pics for a larger image.
Standard front holes
Blank front
Back
Welded corner
More info here:
http://valvestorm.com/1969%20Kit
New 1969 Chassis Available!
- Supporting Advertiser
- JimiJames
Re: New 1969 Chassis Available!
Man ! This is very good news ! This is sure to motivate ! It's starting to feel like the old store. The good ole days yea !
Cheers to Robert and George !
These look great and I will be picking one up to do a '69SL build...giving in to vanity and forever waving goodbye to any remains of sanity in my system.
One question: are the output tube holes punched for NOS sockets or the slightly larger holes for new (i.e. Belton) sockets?
The power tube socket holes will accept the modern (larger) sockets.
- Big Mike
Will the old metro 50 watt front panel work on this (I assumed it's the same as the 100 watter..)
Metroamp kit JMP50 - CM OT
Marshall 2550 Jubilee
Scumback Speakers
Scumback Speakers
Yes they will fit - front panels are the same for 50 and 100w. The JTM45 have a slightly different offset which has to be borne in mind when fitting into a headbox.Big Mike wrote:Will the old metro 50 watt front panel work on this (I assumed it's the same as the 100 watter..)
- Big Mike
Awesome. Thanks Nik!
Scumback Speakers
Scumback Speakers
