50W chassis run
- Brian Wallace
- Supporting Advertiser
50W chassis run
I'm ready to get another run of 50W chassis going. I can make style 1 and style 2 in this run and maybe the trem chassis mentioned in previous posts. Check out the thread here for more information.
http://forum.marstran.com/viewtopic.php?f=21&t=501" onclick="window.open(this.href);return false;
Re: 50W chassis run
Enquries sent.
- Brian Wallace
- Big Mike
Re: 50W chassis run
Always when I'm broke brother! LOL
Next time maybe. (hopefully I'll be workin..)
Metroamp kit JMP50 - CM OT
Marshall 2550 Jubilee
Scumback Speakers
Scumback Speakers
Re: 50W chassis run
Hey Brian, Do you spot weld or bead weld the folded corners on your 50w chassis?
- Brian Wallace
Re: 50W chassis run
Tazin,
Yes, the corners are spot welded and the chassis is coated just like the old Marshall chassis.
Re: 50W chassis run
Hey Brian,
Will the drill hole pattern on top of the chassis be corrected on the new run. Is the price the same and will you have a good stock of ot's and pt's available for the run.
- Brian Wallace
Re: 50W chassis run
TJB,
Yes, I fixed that hole issue when I found it on the first run (one hole was off on the circuit board stand off bolt pattern). I also have plenty of the 50W transformers for these chassis.
- Brian Wallace
Re: 50W chassis run
Didn't see the price, checked the link, maybe I missed that?
- Brian Wallace
Re: 50W chassis run
The cost will be $95 plus shipping.
- Brian Wallace
- Brian Wallace
Re: 50W chassis run
We are half way there. If you are getting more than one chassis please send me a message and I will increase the orders to reflect that.
I can also start taking payments for these chassis if you would like to pre order.
Thanks, Brian
Thanks, Brian
- Brian Wallace
Re: 50W chassis run
I'm happy to announce that all chassis will come with mounting hardware(bolts, cage nuts and washers), Grommets and PT mounting bracket.
