rockstah wrote:my 2cents=
i like to have wires on top as much as possible. makes trouble shooting and tweaking easier let alone having to remove the board for something you could fix in minutes if it were on top.
now sure if you are trying to build a museum piece by all means but if its a player amp and is going to act as foundation for learning amps and tweaking its a different story as far as building goes.... as far as i'm concerned.
I do agree... I've got another true "player" amp that's my testing zone for all mods and tweaks. I really set out on this one because I wanted a pure super lead dressed as nice as I can make her... just because I have to feed my OCD somehow!
As far as trouble shooting... test test test. I test every connection before installing the turret board. If there's a problem hopefully I will have found it that way...
Strat78 wrote:Nice work on that! Those brown boards are nice, I have one and will use it on the next project. I love the shrink tubing on the ohm selector wires, but it makes it hard to experiment with different taps. Where did you get that pink wire from? Also, I really like having the jumper wires under the board as well as not feeding all those wires through the turret board, it looks so much cleaner and confident that way. Are you going to form the caps before firing it up? What tubes?
Yup, I'll definitely be forming the caps first. If you'll notice, I've left the lead that connects to the rectifier with a little extra slack, and the PT common is just hanging out there for now. Insert the 100k, and voila, I should be ready for forming. Right now, I'm planning on trying a range of different power tubes... I've got some EL34 =C='s and some JJ E34Ls that I'm going to try. For pre's I'm going to try the late 60's sylvanias that I just snagged from Terry, or I'll use a cocktail that Doug at Doug's Tubes has turned me onto... Tung Sol in V1, Ruby AC7 HG in V2, and a Sovtek LP in V3. As good as I've had in new production tubes.
