Unpack and inspect the transformers and choke. This build assumes you are using the '68 steel chassis from Metroamp. The hole pattern for the OT (C1998) is matched to the Vintage style end bells. You either have to order a set of the vintage style bells or maybe it can come with them preinstalled as an option. You have to email those guys to find out.
Remove the two screws that hold the end bells on. The wax on the surface of the core will most likely hold them on fairly well. Pull hard, or carefully work them off with a regular screwdriver if they give you trouble. Now you're looking at the exposed OT. The Vintage end bells have four outlet holes. Its up to you how you want to route them but I chose the path of least resistance: the primaries and secondaries get one hole each.
Get the bolts loosely installed and the bolts thread. Keep it just loose enough so you can square everything up on the bench and tighten.
Attach OT and PT as in Metro 100 Watt Instructions. PT is little different since its a laydown style. Instead of tabs with holes on an end bell, you put blts directly through the iron and bolt to the chassis.
Attach choke.
I put the grommets in last.
