12000: Forget step by step I've got a hum
- basisfunction
Re: 12000: Forget step by step I've got a hum
12000 Era Is Still Rockin, 3/11/2011.
Metro '69 100W
Metro JTM45/100
Metro 100W 12000 Era
Metro '69 100W
Metro JTM45/100
- vanhalen5150
- Gunny Highway
- Gunny Highway
- axeman
Replace V3 or swap it. Were did you get those blue capacitors? 220uf/330uf and the 10uf 160v. I've been looking for some of those.
axeman wrote:Replace V3 or swap it. Were did you get those blue capacitors? 220uf/330uf and the 10uf 160v. I've been looking for some of those.
If they're the same ones as on my build, look here:
http://forum.marstran.com/viewtopic.php?f=2&t=334
- Gunny Highway
- Gunny Highway
http://www.mouser.com/ProductDetail/Vis ... T9JJijA%3d" onclick="window.open(this.href);return false;
Those are High Temp (also more expensive) versions... and the datasheet shows different markings.page361 wrote:http://www.mouser.com/ProductDetail/Vis ... T9JJijA%3d
You can find the ones I used here:
http://www.valvestorm.com/Products/Comp ... ectrolytic
- Gunny Highway
- Gunny Highway
- basisfunction
I hadn't noticed activity on this thread. The blue caps are are distributed by Vishay. I sampled directly from the distributor. I will make a concerted effort to record this amp semi-decently. Good luck with your project.
Metro '69 100W
Metro JTM45/100
Metro '69 100W
Metro JTM45/100
- basisfunction
Hey axeman, were you referring to the hum? That issue has been resolved (OT-PT coupling). I have had a few different valves in v3 and no effect has been heard.
Metro '69 100W
Metro JTM45/100
Metro '69 100W
Metro JTM45/100
