Ive just finnished my third 12000 series, but I have some problems with this one.
I cant get any sound out of it! When I crank the volumes to 10 i can hear the guitar, but its very very quiet.
All voltages are fine on the pins!
So far I have:
Double checked wiring
Re-flowed turrets
Tried different tubes
Compared wiring to my other 12000 amp
470Ohm resistor is also correct
Strange problem with new build
- vanhalen5150
Re: Strange problem with new build
Check cables and input speaker jacks with another amp. Recheck your OT wires.
Make sure pins 4 & 5 (red heater wires) of v1-v3 are jumpered at the sockets... post pics...
- Gunny Highway
- Gunny Highway
- VelvetGeorge
- Site Owner
Do you hear a sound when you touch plate terminals with your meter?
Start at the output tubes and work your way backwards through the amp until you don't hear a sound when you touch your meter lead to the plates.
Thanks for help
I hear a sound when i touch the plate terminals with my meter. I am at work now, but if I remember correctly the "sound" stops at V1. I have also tried tubes that I know works.
I fixed it! The 100k resistor on the pins in V2 was installed wrong : )
Good ol' Larry, I hear you...
