12002: 2" OT
- vanhalen5150
- vanhalen5150
Re: 12002: 2" OT
Playing for a few hours this weekend. V4 has a dark tint to the glass now. Started getting some serious red plating on V5. I mean it was GLOWING!!! Trannys seemed normal temp.
Decrease in volume and some snap crackly pops. Shut it down. Waited an hour. Turned it back on for a few mintes, seemed fine.
I'll give it a go again and see if I can replicate with photo's or maybe video. Not sure the KT77's are really great for wide open.
Time to check all the voltages I guess.
- Strat78
Re: 12002: 2" OT
Are you biasing to the hottest tube still? You are really mean to your tubes, didn't you blow a hole in the ceiling with a tube last year?
- vanhalen5150
Re: 12002: 2" OT
Yeah. Thats the same position (V5) I blew the 6CA7 into the ceiling. It's been good ever since. I thought it was the tube but there must be more to it. I'll do up a voltage chart most likely. The KT77's sound thin and much brighter than other tubes. I think thats why guys like them for metal.Strat78 wrote:Are you biasing to the hottest tube still? You are really mean to your tubes, didn't you blow a hole in the ceiling with a tube last year?
I havent hade this thing on the bench in quite a while.
- vanhalen5150
Re: 12002: 2" OT
Redplating on V6.
- photo.JPG (124.47 KiB) Viewed 12614 times
- vanhalen5150
Re: 12002: 2" OT
Vid. Not sure why its rotated. I had to cut it down to under 2Mbs to fit here.
I'm just kinda banging away on the strings to see when it occurs. I think Im playing Dream Theater or something on the playback.
This is after about 5 minutes.
Would you guys like me to TAB that out for ya!
- IMG_1053.MOV
- (1.79 MiB) Downloaded 2028 times
- vanhalen5150
- Strat78
Re: 12002: 2" OT
OOOOH AHHHHHH, have they come for us at last?
Re-flow everything in the neighborhood or try a new socket.
- vanhalen5150
Re: 12002: 2" OT
Yeah, good thing its not in a headbox, because I wouldnt have seen it doing that.
I'm going to check all the voltages, move the tubes around. When it lights up there is a slight decrease in the volume and then it comes back up.
I never really knew what redplating looked like until I saw this. It looks purple in the vid a pic but its actually a bright orange/red glow.
Why do I find this exciting?
- rgorke
Re: 12002: 2" OT
very pretty!!!!
Mine did that a while ago, the tubes wasn't seated well in the socket. However, since you were playing for 5 mins....not sure. Is this the same amp and socket that shot the tube through the ceiling?
- vanhalen5150
Re: 12002: 2" OT
No. This something new. It's V6. The explosion was V5. That glass on the tube at V5 has turned a dark smoke color. On the bench doing some investigative work today.
