for the bias resistor, have values on hand that measure around 27k, 33k, 47k or 56k. Start with a 33k and see where that lands you as far as having enough play with the trem pot. You really need to get a variac befor running those tubes. The EH's seem to dislike voltages above 400v. I keep the plates at around 350 to 385. Ben's amp is at around 350v. According to the formula the bias should be around 46, but it sounds pretty killer up around 51. Another factor is a Drake tranny clone verses the Dognal. The Drake's "132" seem to perform much better with the lower voltage and high bias, where as the Dognals seem to start farting out.
You want a variac with 120v input with 7 to 10amps, 0 to 120 or 140v output. I like the old Ohmites for obvious reasons, but they only come up once a month or so on ebay, and chances are that I will outbid you.
