I'm certainly not reinventing the wheel here, in fact I'm ripping alot of you guys off in most respects, haha! But I guess everyone has their own take on a 12,000 and besides, we never get tired of looking at amp pics, right?
I'm not going strictly for VH, I want a sound that only a plexi will get, but I am curious how close it will be right off the bat. I wouldn't consider myself a VH player but messing around with it from time to time is pretty fun! Here's some of the specs, subject to change of course:
- Metro 12,000 chassis I got shipped from neikeel in England, right before George started making them available again, ha!
- pretty much DF spec except I'm going with 64uf in the P.I. instead of the 100uf to start with
- 2" Marstran 132 2.5k high-impedance OT, this is one from the run Brian did a while back
- M****n PT, using the lower 465v B+ tap and eventually a Variac to bring it down around 400v
- Brian H boards
- Mustards, Pihers and (mostly) Iskras, oh my!!
- Larry grounding
- EH 6CA7s
This will probably take a little while, but hopefully I'll have it up and running in a few months or so.
This is the same rotating amp cradle I made that I used on my first build (JTM 45), but just changed the bottom piece out for the Superlead:
Went round and round about the power jack and came to the conclusion that the IEC was the best choice. I used a vintage Bulgin on my JTM45 build and it has proven to be a giant pain the ass when it comes to gigging, if you're strictly playing at home then it's fine. I love how they look but I drag my amps eveywhere and Bulgin plugs just aren't reliable enough for me:
Got a cool looking 70's Bakelite one off of ebay. Well, as cool as an IEC can be:
Next mounted the trannys, looks crushing!!
Used the vintage-style Classictone trans brackets for the OT, had to drill two holes to accomodate the huge 2" 132 and another hole for the primaries:
Finished the heater wiring, decided to use 18 ga wire for the power tube sockets and 22 ga for the pre-amps. Did some reading on this thread started by vanhalen5150:http://forum.metroamp.com/viewtopic.php?f=44&t=35338
Some of the amperage numbers posted by vh junkie were interesting, so I got a little crazy and used two different gauges! Maybe a little over the top?
18 ga isn't as easy to work with in a tight space as you would think, ha:
