120V indicator lamp hookup with 240VAC supply question
ivan H
Post by ivan H » Tue May 21, 2013 6:39 pm
Hi, I'm hoping someone can advise me, I have a 120V indicator lamp & the supply here is 240VAC. Should I connect the indicator with one lead to the supply common & the other to the 120V tap on the PT primary, or should I hook one lead to the cold side of the power switch (240VAC, Active) & the other lead to the 120V tap on the PT primary, or does it not really matter which way its hooked. Thanks in advance for any help. Cheers
Brian Wallace
Supporting Advertiser
Re: 120V indicator lamp hookup with 240VAC supply question
Post by Brian Wallace » Wed May 22, 2013 8:32 am
One lead to the PT common and one lead to the 120V PT primary tap.
Patience is a virtue.
Wallace amps
Wallace forum
ivan H
Post by ivan H » Wed May 22, 2013 4:58 pm
Thanks Brian, it's looking good so far, I'll shoot u a couple of pics. Cheers
Brian Wallace
Post by Brian Wallace » Wed May 22, 2013 9:11 pm
Looking forward to it Ivan. :)
Wallace amps
Wallace forum
