I use these switches from TAD in Germany. They are very tightly linked with MOJO so might be worth trying?
https://www.tubeampdoctor.com/en/shop_P ... rvolume_29
I can send you a pot (postage is not too bad).Explorerman wrote: ↑Wed Feb 06, 2019 3:39 pmI'll check them both out, however with shipping Australia it starts to get pricey. Still thinking I might use 2 x of the CTS with SPDP (on the 1987 bright vol and master vol) that VS have, I plan to use CTS pots on the amp.
I realize its controversial topic regarding resistor and capacitor types, but I read an article saying the only place to gain any benefit from carbon comp resistor it at v2 plate, is this right? Also, the layout has silver mica caps except for the bright cap which looks to be ceramic - is this correct?
Neikeel, I sent you a PM regarding the pot, but looks like its stuck in my outbox, I can't seem to work out why it won't send...neikeel wrote: ↑Wed Feb 06, 2019 4:51 pmI can send you a pot (postage is not too bad).Explorerman wrote: ↑Wed Feb 06, 2019 3:39 pmI'll check them both out, however with shipping Australia it starts to get pricey. Still thinking I might use 2 x of the CTS with SPDP (on the 1987 bright vol and master vol) that VS have, I plan to use CTS pots on the amp.
I use Pihers and generally avoid cc resistors unless like for like in a resto.
I also use RS silver micas and mustards (I pick them up here an there when I find good prices on them as my original stashes have run out).
Yes you are correct regarding kit specs.
The reason I use an extra pot is that I can set my plexi and my 2204 pots and switch between the two quite quickly for different tones (I have been too busy with other stuff to footswitch this one but the Granger optofet jack works well.
