Bias ajustment and the larmar PPIMV
ignition
Post by ignition » Wed Nov 18, 2009 9:23 am
I have a 100w Metro kit that I added the larmar to. When adjusting the bias the larmar should be turned all the way up and Volume 1 & 2 turrned all the way down..... Is that correct?
Re: Bias ajustment and the larmar PPIMV
Post by Roe » Wed Nov 18, 2009 10:13 am
the MV setting wont matter. but don't send a signal through the amp when you set the bias. however, play the amp at 10 afterwards and look for redplating
sixpakldp
Post by sixpakldp » Thu Nov 19, 2009 12:38 pm
Turn the Lar/Mar all the way up and Bias the amp. Keep your Volume knob low until you get it set right.
As you turn down your Lar/Mar your bias will also go down. So if you bias with the Lar/Mar very low, you'll end up with too high of a bias.
To check what I'm saying, turn your MV knob to a different position than when you biased it, you'll notice that it changes with respect to the position of the MV knob.
Post by Roe » Thu Nov 19, 2009 1:29 pm
no the larmar does not affect the bias settings
MacGaden
Post by MacGaden » Thu Nov 19, 2009 1:35 pm
Roe wrote:no the larmar does not affect the bias settings
+1. If it does, something else is wrong.
MacG.
ignition
Post by ignition » Thu Nov 19, 2009 2:57 pm
I couldn't imagine why the MV would affect the bias settings, but I've seen procedures mentioned similar to what sixpakldp mentioned in his post. Just trying to make sure I had a handle on the circuit. I did mess with the volume levels after setting the bias, and they didn't move at all.
sixpakldp
Post by sixpakldp » Thu Nov 19, 2009 4:20 pm
Interesting . . . I only passed this on because I was told these instructions and I also noticed that when I turn the MV up to 10 my bias in mV off of pin 3 is maxed, when I turn the MV down my bias on pin 3 I see a reduction in the mV at pin 3.
I passed this info along because Structo/Tom told me that this is correct and that you should bias your amp with the MV at 10 and your Volume at 0 and also that I am correct that the MV does affect the bias current.
Let me know if this is the case because this trend is true in my amp and I am also having problems with the amp. See my post about redplating and fuses blowing, you'll see the post from Structo giving me these instructions about 3/4 of the way down page 1.
sixpakldp
Post by sixpakldp » Thu Nov 19, 2009 4:25 pm
Also,
See Georges notes for the Metroamp PPMIV. Although this is a different PPMIV, he states the MV should be cranked and the amp should be rebiased.
Here are the instructions:
http://metroamp.com/wiki/images/c/c5/PP ... y_Step.pdf" onclick="window.open(this.href);return false;
toner
Post by toner » Thu Nov 19, 2009 5:42 pm
It shouldn't but does, at least in my experience.
more:
http://forum.metroamp.com/viewtopic.php ... 76#p281276" onclick="window.open(this.href);return false;
SDM
Post by SDM » Thu Nov 19, 2009 10:13 pm
more:
Should keep in mind that the meter combined with a PPIMV at various settings can be misleading when reading the negative bias voltage as opposed to bias current. Meters have a very high internal impedance when measuring DC, usually many Megs, but cheaper meters may have much lower internal resistance, and regardless it can still throw of measurements of - bias at pin 5s of the power tubes.
Example say a you have a cheap meter, specs say only 1Meg input impedance for DCV measurements. This means the meter itself looks like a 1Meg resistor and forms a voltage divider with the PPIMV pot (or just the 220Ks if no PPIMV is used) when measuring for negative DC at power tube pin 5s.
Ignoring grid stoppers, this means talking a measurement at pin 5 with PPIMV maxed (or a stock no PPIMV set up), you now have a 220K/1Meg voltage divider that otherwise wouldn't be there in normal operation (if meter was not there talking a measurement). With PPIMV off, the voltage divider disappears as the power tube grids and 1 Meg of the meter are now directly shorted to the -bias source.
Ignoring the 1Meg in parallel to the bias pot and resistor here, with PPIMV off/set at zero, say you measure -45V with this meter at pin 5s. Assuming there is no grid leakage from the power tubes, you'd then expect to see attenuation of that voltage reading when the PPIMV is then cranked to max. With this meter, attenuator/voltage divider is 220K/1000K now approx, so you'd expect the voltage reading to be reduced by 220k/1220K=18%, so would read about -36.9V now on pin 5s. So here the meter itself being in the circuit is changing your readings. If the meter was not there, the voltage divider would not be there and thus there would still be the original -45V on the grids PPIMV whether cranked or set to 0.
A better meter may have say a 10Meg input impedance. So say the same deal, measure -45V with PPIMV off, now have a 220K/10,220K voltage divider, so would expect to see the reading drop from -45V by 22K/10220K=2.15%, so about only a volt drop now to -44V. Again if the meter was not there, as would be the case when the amp is operating as normal, this drop would not be/isn't there either, voltage really is still at-45V.
All that said grid leakage can/does happen too, can follow Toner's link above to read up on that I think, but the main point is that the meter itself and quality of it can be a very misleading thing regarding pin 5 readings with different PPIMV settings. Meter specs effect how much the PPIMV setting seems to effect the - bias voltage reading. Better meters will read less change, cheaper meters more change, and that change you see well may not really there in normal operation with the meter out of the circuit - at least most of it as there could be/is some grid leakage in play.
Since grid leakage can be/is still a factor, that's the main reason you should bias with PPIMV maxed IMO, but the above is more for those of you with huge differences in - bias voltage readings like Toner had and who this response is mainly for (should have elaborated on this meter issue first time you brought up your large - voltage change). That - voltage change may well not be anything to worry about, mostly not even really there, just your meter throwing readings off. Best test is to keep an eye on the bias reading across the 1 ohmer, or whatever method you use, to check how the bias current itself changes through the PPIMV sweep. That eliminates the meter error in just checking pin 5s, and you'll know if your bias current does or doesn't really change through the PPIMV sweep, how much grid leakage plays a part.
Hope that made sense.
toner
Post by toner » Thu Nov 19, 2009 10:27 pm
Great info as usual Steve. To be fair and just so others know, I have a fairly cheap meter (not rat shack level but also not a high-end Fluke, etc.). I just don't have a need for an expensive meter with how little it's used.
sixpakldp
Post by sixpakldp » Fri Nov 20, 2009 6:39 am
That was an excellent explanation.
I also have a cheap meter. Prior to owning my amp, I mainly used it around the house when doing electrical work.
Structo
Post by Structo » Sat Nov 21, 2009 2:27 pm
sixpakldp wrote:Interesting . . . I only passed this on because I was told these instructions and I also noticed that when I turn the MV up to 10 my bias in mV off of pin 3 is maxed, when I turn the MV down my bias on pin 3 I see a reduction in the mV at pin 3.
Pin 3 is the plate or output of the power tubes. This is where the output transformer primary winding is connected.
You measure plate voltage there, not any current or bias voltage.
for bias measuring you measure in DC volts across the 1 ohm resistor on the cathode of the tube. Pins 1 and 8 should be joined and the 1 ohm resistor from there to a ground lug on the mounting bolt of the tube socket.
Tom
Don't let that smoke out!
uiovbged332
Post by uiovbged332 » Wed Jul 06, 2022 7:28 pm
Nike Clearance
Nike Shoes For Women
Pandora Charms
Nike Air Force 1 Men
Air Force 1 Mid
Christian Louboutin
Red Bottoms Louboutin
Nike Shox For Women
Nike Lebron 16
Nike Factory
Pandora Canada
Nike Outlet
Ferragamo Shoes
Nike Outlet Store
Nike Shoes
Christian Louboutin Outlet
Pandora UK
Pandora Necklace
Christian Louboutin Shoes
Louboutin Shoes
Adidas Yeezy Shoes
Ferragamo Outlet
Nike Basketball Shoes
Nike Air Max
Vans Shoes Outlet
New Nike Shoes
Nike Shoes
Nike Free Run
Kyrie Shoes
Ultraboost
Moncler Outlet
Nike Shoes
Nike Store
Sneakers Website
New Shoes
Adidas Stan Smith Sneakers
Nike Running Shoes
Nike Sneakers
Nike Shoes
Nike Air Max 270
Womens Nike Shoes
Christian Louboutin
Air Max 720
Golden Goose Shoes
Yeezy Shoes
Pandora Bracelet
Jordans Sneakers
Red Bottom Shoes For Women
Air Force One Nike
Lebron 17 Graffiti
Louboutin Shoes
Nike Factory Store
Valentino Sandals
Nike Cortez Women
Adidas Sneakers For Men
Nike Zoom
Nike Black Friday 2020
Nike Presto
Yeezys
Louboutin
Red Bottom Shoes
Nike Factory
Asics Outlet
Christian Louboutin Shoes Outlet
Air Jordan Sneakers
Lebron 16
Michael Jordan Shoes
Nike Clearance Outlet
Pandora Earrings
Nike Outlet
Lebron 16
Nike Factory
Yeezy Sneakers
Jordan Sneakers
Fjallraven Kanken
Kyrie Irving Shoes
Nike Sneakers For Men
Nike Outlet Online
Adidas Yeezy
Nike Outlet Store Online Shopping
Nike Shoes
Jordan Retro
Nike Running Shoes
Nike Air Uptempo
Nike Air Zoom
Adidas Ultra Boost Women
Pandora Charms
Yeezy
Fjallraven Kanken Backpack
NMD Adidas
Jordan Shoes For Kids
Nike Sneakers
Nike Factory
Pandora Jewelry
Christian Louboutin Shoes Sale Outlet
Cheap Basketball Shoes
Adidas Yeezy
Air Max 720
Nike Huarache Men
Nike Air Max
Cheap Nike
Nike Factory Store
Air Max 95
Christian Louboutin UK
Nike Running Shoes
Nike Outlet Store
Red Bottoms
Nike Shoes Outlet Online Store
Pandora Jewelry Official Site USA
Nike Shoes
Air Max 2019
Nike Store
Christian Louboutin Heels
Nike Clearance
Jordan 11 Retro
Air Force Ones
Kevin Durant Shoes
Pandora Rings
Pandora Rings
Air Max 98 Gundam
Nike Outlet Store
Ferragamo
Air Jordan 13 Retro
Pandora Canada
Lebron Shoes
Nike Free rn
NMD R1
Pandora Sale
Pandora
Pandora
Pandora Jewelry
Retro Jordans
Pandora Bracelets
Jordan 11 Blue
Yeezy 500 Blush
Nike Air Max 98 Gundam
Yeezy Boost 350
Nike Outlet
Yeezy Boost 750
