Super 100JH clone
Posted: Wed Jan 23, 2013 7:29 am
by malaki
Hi,
I wanted to buy this amp, but unfortunately it's not possible to buy it anywhere,
so I found this forum and now decided to build an clone of the amp,
where should I start?
my first idea was to study the 2 build guides in the wiki and study the rest of the wiki,
then also i'm not sure if I can get all the exact same parts that were used in the 100jh,
are they available somewhere? because I wanted to build an exact 1to1 copy
is this schematic 100% accurate and the same as the 100JH that was on the market?
http://forum.metroamp.com/viewtopic.php?f=25&t=33576" onclick="window.open(this.href);return false;
thanks for your help,
Re: Super 100JH clone
Posted: Wed Jan 23, 2013 9:15 am
The Marshall one you link to looks ok.
There is this one too:http://www.marstran.com/HendrixAmpMod.gif
It is a '66 JTM45/100 with slightly altered tone stack:http://www.pleximods.com/hendrixmod.html
Also V1 has extra 10k dropping resistor and more filtering like the slightly later amps. A stock '66 has 16uF cap on the board, but the '67 has a dual 32 uF cap with the 10k between the limbs.
Look at the photos too.
I have one all ready to build but little time - make me an offer (a good one!)
Posted: Wed Jan 23, 2013 5:04 pm
by malaki
you mean an offer for the parts?
Posted: Thu Jan 24, 2013 3:52 am
I am in the UK.
Marstran alloy chassis
Marstran transformers and choke
Brian H boards, NOS mustards and Pihers, both plexi panels, pots, knobs, NOS sockets, ie the whole shooting match for a NOS HW Hendrix amp, only lacking a head cab (going to get one of my 67 narrow vent cab cloned by Chris Huff). Time is tight, I have lots of Marshalls already so will only sell if really good offer, failing that I will build it when I get chance.
Re: Super 100JH clonei
Posted: Fri Jan 25, 2013 12:54 am
by malaki
i have no idea what that stuff is worth, since this is the first time I build an amp
and I don't even know if these are all the parts I need, I need to learn more about building an amp first,
Posted: Fri Jan 25, 2013 6:07 pm
malaki wrote:i have no idea what that stuff is worth, since this is the first time I build an amp
No worries! Shop around and see what you need and get it all together, sometimes chasing all the small parts its part of the fun.
I just need more free time!
Posted: Sun Jan 27, 2013 3:51 am
by malaki
i've read through the 2 instruction pdfs and I wonder how dangerous this is for a beginner like me,
i have experience soldering , but the testing part at the end with the high voltages seems risky to me
what do you think? maybe I should just buy an already built amp or is this safe for a beginner if you are careful enough?
Posted: Sun Jan 27, 2013 4:43 am
by jimmyride
Of course it's dangerous. But it's also great fun. You just have to be careful and follow the instructions. I also built my amp with no experience whatsoever.
Posted: Tue Jan 29, 2013 1:17 pm
by malaki
does anyone have a good highres picture of the inside of this amp?
( higher resolution than the one on the marshall page) ?
Posted: Tue Jan 29, 2013 2:13 pm
Have alook here, these should zoom up quite well:
http://amparchives.com/album/Marshall/1 ... index.html
These are what I am working off :wink:
Posted: Wed Jan 30, 2013 6:35 am
by malaki
neikeel wrote:Have alook here, these should zoom up quite well:
thanks, that helps a lot,
im wondering, is there any chance of getting the transformers that marshall used in the jtm45100 reissue and super100jh?
i guess if marshall got drake to rebuild those, there could be a few more available?
Posted: Wed Jan 30, 2013 7:17 am
by demonufo
You would probably need to provide a serial number to get those out of Marshall.
But, in all honesty, you could do much better than those anyway. MUCH better.
Posted: Wed Jan 30, 2013 7:21 am
by malaki
demonufo wrote:You would probably need to provide a serial number to get those out of Marshall.
what do you think is better?
i read that these ones are exact replicas of the old ones but I have no idea,
Posted: Wed Jan 30, 2013 9:20 am
by malaki
is there a list of the different chassis suppliers/producers on this forum?
Posted: Wed Jan 30, 2013 9:45 am
by demonufo
You'd be better off with Heyboer clones. Give Brian at Marstran a shout. Drake and Dagnall have been poop for years.
