Need help wiring a 1202-118 Marstran PT
Turd Ferguson
Post by Turd Ferguson » Fri Feb 14, 2014 11:21 am
Need advice with Marstran 1202-118 PT I am building Metro 50 and need help with wiring Trans. it has terminals for secondary's they are listed like this below need to know where each wire connects to such as I believe that high HT go to bridge rectifier
A=5VAC
B=5VAC
C=HT HIGH
D=HT LOW
E=0
F=HT LOW
G=HT HIGH
H=COMMON
I=3.15 VAC
J=0
K=3.15 VAC
Turd
Re: Need help wiring a 1202-118 Marstran PT
Post by Roe » Sat Feb 15, 2014 10:01 am
Turd Ferguson wrote:Need advice with Marstran 1202-118 PT I am building Metro 50 and need help with wiring Trans. it has terminals for secondary's they are listed like this below need to know where each wire connects to such as I believe that high HT go to bridge rectifier
A=5VAC TO GZ34 RECTIFIER IF YOU HAVE ONE
B=5VAC TO GZ34 RECTIFIER IF YOU HAVE ONE
C=HT HIGH TO RECTIFIER
D=HT LOW
E=0 GROUND
F=HT LOW
G=HT HIGH TO RECTIFIER
H=COMMON GROUND
I=3.15 VAC HEATER
J=0 GROUND
K=3.15 VAC HEATER
Turd
