I picked up some Riffa 330uf, 63A electrolytic's with the intention of putting one on the cathode bypass.
The trouble is the more I think about it I seem to remember reading that anything over 6A will sound really bad here.
I can't find the post to either confirm or denie this, does anyone know anything about this?
Cheers
Cathode bypass voltage?
Re: Cathode bypass voltage?
The cathode voltage of the preamp tube is extremely low. Any cap rated 10 volts or higher will be fine. You would normally use a low voltage cap here because of the limited board space. A higher voltage electrolytic cap would be much larger and cost more than a lower voltage. I'm not sure that a higher voltage cap would necessarily sound bad though. Gibson used 400v bumblebee caps in the 159 Les Paul where a 5v cap would have been more than enough. They seem to sound pretty good though.
Ok, that has me feeling a little more at ease. The thing is those bumble bee's are paper in oil and what I can't seem to remember was it was something about electrolytic's not working properly if their rating was way higher than what was applied across them.
I had a feeling it was either a post from Nekeil or Novosibir...?
I sure hope I'm wrong 'cos those Riffa would look awfully sweet right in there.
A 63 volt cap will be just fine. If it was 600 volt I might reconsider using it. Fender used 25 volt bypass caps on all of their amps for years when a 5 volt would have been sufficient.
I think you meant 6v.revolver1 wrote:Ok, that has me feeling a little more at ease. The thing is those bumble bee's are paper in oil and what I can't seem to remember was it was something about electrolytic's not working properly if their rating was way higher than what was applied across them.
But no, not me, guvnor! Voltage rating can be what you want. It is the microfarad value that I prefer to keep lower than stock. 330uF is full bandwidth and some more!
25uF is plenty on a shared V1 (or even split on a V1a NMV) cathode. Voltages on cathodes of the preamp tubes (except cathode follower are negligible - take a squint at at chart).
Thanks guys.
