How to calculate sample rate in ADC
ROSELJR
Post by ROSELJR » Fri Feb 25, 2022 9:52 pm
A 12-bit analog-to-digital converter, the working voltage is 5V, the working frequency is 1MHz, how to calculate the sampling rate, why some sampling rate units are Hz, and some are sp/s, s/s, does anyone know what it means? , can you tell me how to calculate?
Introduction of ADC: https://www.utmel.com/blog/categories/i ... ling-rates
Freebird
Re: How to calculate sample rate in ADC
Post by Freebird » Sun Mar 06, 2022 5:52 am
Hi Roseljr
One has to know, that 1 Hz (Hertz) is the same as 1 sp/s (sample per second) and also is equal as 1 s/s (sample per second).
And that a sample rate means how many time a signal will be sampled each second.
I hope that helps you.
Best regards
Daniel
metroy
Post by metroy » Tue Jan 31, 2023 1:37 am
Indic Input is completely free to use. It comes with extensive help documentation that explains everything there is to know about Indic Input. Install Indic Keyboard For PC
