Is it safe to run a 100w amp at 50 watts longterm?
Im getting ready for my next build and I'm thinking about a 100 watter. Problem is I only have enough cabinet for a 50 watter and would probably run this amp im 50 watt mode most of the time by pulling 2 tubes. Will this hurt the amp longterm?
Finished amps --> Metro JTM45, Champ, Deluxe, Bandmaster, 1974x
Still Debugging --> Metro 50, Trainwreck Express
- mc_guitar
Re: Is it safe to run a 100w amp at 50 watts longterm?
No Problem, if the electrolytic caps can stand the higher voltages, but they should anyway! But keep in mind, that you have to change the impedance on the switch as well!
Cheers Michael
Cheers Michael
Plexi rules...
