2203 build, no power at speakers?
Posted: Thu Feb 02, 2012 4:28 pm
I just finished my second build from George. I checked all voltages and bias twice. I'm not even getting a hiss from the speakers. (I checked the cab with an amp, no problems)
I used input cliff jacks on the outputs, possible problem?
I tried getting readings across the cliff jack and impedance switch. I was looking for the 13.4 ohms I have from the cab. Basically not getting a reading.
The PI resistors are all correct.
Is there a way to read the imp. switch to check for power? I hate to keep checking things with no load; not sure if the amp is seeing a load at this point.
Tubes are not redplating.
Much thanks!
Much thanks!
