Pulled the board to make sure there were no pinched wires, everything looked good, replaced the board. Going through everything now to make sure there are no stray wire strands jumping terminals, but really I'm not seeing anything that draws my attention. So I ran back into the garage and started over with testing. Preamp tubes light up, voltages are good coming in and heater voltages are all good. Negative bias voltage is good as well. That's all I get, because the next step is to throw the STANDBY. Another blown mains fuse. Can anyone offer some suggestions?
--voltage selector wiring--
PT primary common: rocker terminal 11 (bottom left)
Mains iec "N": rocker terminal 12 (top left copper)
Mains fuse: rocker terminal 25 (top right copper)
V selector center term: rocker terminal 24 (bottom right)
PT primary 120/220/240 voltage taps: corresponding terminals on V selector. I made sure I had the correct terminals by checking continuity between the different terminals and center terminal as I switched through the different settings, prior to hooking it up.
