I'm building the kit and following the instructions but the wiring color coding doesn't match the instructions.
They are Classic Tone #40-18072 OT and #40-18053 PT.
I've tried attaching diagrams for both, but "Sorry, the board attachment quota has been reached."
CT Transformers
Re: CT Transformers
http://www.classictone.net/40-18072.pdf
Pretty straight forwards looking at the wiring diagram for this one?
http://www.classictone.net/40-18053.pdf
Do your transformers have the codes on the diagrams?
In which case you should be able to apply these to your schematics pretty easily.
Re: CT Transformers
First off, please be sure you are working safely. Tube amps can kill you even when turned off and unplugged. Be sure you know the proper procedures for safely working with this equipment including how to safely discharge capacitors.
MetroAmp 1203-80 to ClassicTone 40-18053 Wire Mapping
MetroAmp C1998 to ClassicTone 40-18072 Wire Mapping
- Gunny Highway
- Gunny Highway
Re: CT Transformers
Thank you sir, perfect.
Much thanks!
Much thanks!
