Ed's 1978 touring rig.
adamsapple
Re: Ed's 1978 touring rig.
Post by adamsapple » Sun Mar 15, 2009 5:31 pm
So it appears we've ruled out the power resistor tied across the plates mod ever being used (ala ******/twistneck), no?
Plexi Clone (MM OT, Sozo+ Caps)
Wolfgang Special with CustomCustom bridge
EP3 Echoplex
MXR Reissue Flanger, Phase 90, 6-band EQ
Ruby Tubes 2X12 with G12H30's, G12M's
Boss GE-10
StuntDouble
Post by StuntDouble » Sun Mar 15, 2009 5:47 pm
I've wondered that too. Apparently the cap across the back was for the master volume, but I recall reading an interview with Ed where he talks about a cap...probably a resistor..."that sucks juice". Wa this just Ed making stuff up or a reffernce to what we now reffer to as the ******* mod; I'd like to know too?
rockstah
Post by rockstah » Sun Mar 15, 2009 5:48 pm
adamsapple wrote:So it appears we've ruled out the power resistor tied across the plates mod ever being used (ala ******/twistneck), no?
a long time ago. ;)
fivecoyote
Post by fivecoyote » Sun Mar 15, 2009 5:57 pm
Awesome. Many thanks, Robin L., Mark Cameron and everyone else for the insight. It's just as awesome that Rockstah found all of this out, give or take, on his own and got "the" sound.
Questions for Robin:
1. Do you know what Seymour did to the pickups he altered for Ed? Any details or hearsay would be great.
2. Did Ed say anything about why he liked brass nuts?
3. Did he mention what type of bridge he liked the best?
4. Did he mention liking any types of tuners better than others?
5. Did he stick with the Ohmite brand of Varaic or did he use others?
6. Did he like any kind of guitar cable (guitar to amp) in particular or did he use whatever he had?
7. How much cable (length) between the guitar and the pedal board?
8. Did he alter his whammy bars at all?
Trying to nail down as many details as possible!
Thanks again.
At it awhile, still learnin'
adamsapple
Post by adamsapple » Sun Mar 15, 2009 6:09 pm
"a long time ago." I've been away from this forum for a while. good to be back. I wonder what that says about u know who's credibility. I for one tried the "bass ckt" for evh and never thought it sounded right. way too flubby.
EP3 Echoplex
Boss GE-10
Mr. Beasty
Post by Mr. Beasty » Sun Mar 15, 2009 6:12 pm
vh junkie wrote:OK! Strings 9-40 fenders! I know a lot of this has been posted before... but seeing how a lot of it was wrong, I just wanna be complete... springs in the back... what do you remember about those? Tremolo setup? I used to hear people back in the day say "closes like a garage door"... but the common setup has some float...
... no agenda here by me... I'm on board!
I think this one is easy because Ed never had back plates on his guitars so there are tons of live pictures showing the back of Ed's guitars.
He is know to have never used floating trems. Most guitars had two to three springs.
The three set-up was the traditional one straign-two slants. The two spring set-up usually was the same as the three springs minus the centrer straight spring. Sometimes, the two spring set-up was one straigh spring and one slanted. Sometimes both srings would be parallele to one another but set diagonally across the cavity.
Conclusion: whatever position was needed to get the tension right.
http://www.fuzzymonsters.com
http://www.myspace.com/fuzzymonsters" onclick="window.open(this.href);return false;
Mr. Beasty
Post by Mr. Beasty » Sun Mar 15, 2009 6:43 pm
Robin L.
Is this the style of "stick of dynamite" resistors Ed used for slaving in the early days?
Thank you.
papawoofer
Post by papawoofer » Sun Mar 15, 2009 6:45 pm
MarkCameron wrote:
None of this was new or strange to me...it was very simple....alot of guys I knew did this stuff. But this is the stuff that I was into and doing in 82 for friends and bands I worked for.... BUT Eds playin.....thats the big thing...this stuff is just the iceing on the cake
Mark do you know of any recordings of people you worked with so we can compare?
GARY
Grosh_Guitars
Post by Grosh_Guitars » Sun Mar 15, 2009 7:39 pm
I've read in a few places that using a variac can actually cause all sorts of problems, including blown OT's.
(scroll down to the picture of a variac)
http://tone-lizard.com/Marshall_Myths.htm" onclick="window.open(this.href);return false;
Man that guy sounds bitter :lol:
It seems like the use of the the variac and the fact that Ed had the variac'ed marshall dimed for at least one show a night probably led to lots of blown OT's and, depending on the voltage he set it to, blown tubes.[/quote]
Variac's are fine when used properly. I used one for years on a 62 Fender Bassman, I just biased the amp seeing that 90 volts at all times.
Robin thanks for the info!!!
Sound Clips: http://www.soundclick.com/bands/default ... tent=music" onclick="window.open(this.href);return false;
ROBIN L.
Post by ROBIN L. » Sun Mar 15, 2009 8:02 pm
MarkCameron wrote:
Its nothing special...Its just a later brighter 74 style circuit in there....not the 68 circuit. The transformers are ...or where....mid 70s too
Well that's really interesting, because that amp never sounded like Ed's mid 70's metal plate super leads.
See, when he bought it, that amp had the master volume knob in the back, it was bought secondhand.
Maybe when he bought it,, its circuit had already been changed or modified to that of a mid 70's superlead(hence the master volume in the back).
So it wasn't a plexi from the beginning ! :?:
Frankly I don't think this is correct but ...
I would tend to think it had the 68 circuit when Ed bought it, because it sounded a lot sweeter than the later mid 70's metal plate Marshalls (more mids, crispy highs but not ice picky).
It sounded just like those 50 watt smallbox plexis Ed owned, but had more chest.
Having seen that amp fry and blow up so many times because of Ed's abuse, its transformers replaced many many times, and considering all the repairs and service done by Jose, it 's likely that it wasn't the same amp by the time you serviced it.
What year was that Mark ?
ROBIN L.
Post by ROBIN L. » Sun Mar 15, 2009 8:04 pm
Mr. Beasty wrote:Robin L.
Thank you.
Those have nothing to do with slaving.
papawoofer
Post by papawoofer » Sun Mar 15, 2009 8:20 pm
MarkCameron wrote:
ROBIN L. wrote: Jose Arredondo built a few prototypes for Ed.
The one used by Ed on the 1978 world tour featured 2 inputs, a volume knob, and 3 line level outputs.
That volume knob was used to control the overall stage volume of the rig.
The 2 inputs were fed with the speakers outputs of the main plexi and the 50 watt smallbox plexi
This is the one I have....from people who would know.....have said to me..it may be one of the ones he used ...what do you think???
Mark from your pics it looks like there are 3 different loads there, 2 with their own cable, and 1 as a box you plug into, I mean I dont see any wires connecting the resisters. Am I missing something?
GARY
vh junkie
Post by vh junkie » Sun Mar 15, 2009 8:37 pm
Thanks Beasty!
I just would like Robin to weigh in on how this was setup... how did he exactly tweak all this... perhaps common knowledge is correct on all this, but maybe not...
At any rate, it would be useful to edit the core of the thread to include any relevant info here!
- Gunny Highway
MarkCameron
Post by MarkCameron » Sun Mar 15, 2009 11:41 pm
This might be the closest on recording that I can find.....its an ---old JB pickup--fl--ph90--EP--to the amp..but no slaving.....just turned up to stupid volumes on this song......also a 57mic and 25watt greenbacks in an old Marshall cab that Jose wired up....LA2A---EMT Plate Rev..every thing is 1 or 2 takes....fx are all live...not added.............
This song might sound familiar :lol: :D
Check out......Half Way Home....
This is the only place I could find that you can hear it online.......
http://musparade.com/album/John+Norum/A ... estination" onclick="window.open(this.href);return false;
MarkCameron
Post by MarkCameron » Sun Mar 15, 2009 11:54 pm
Its just what Jose would do. I can hear on boots that it first had the stock circuit. I don't think one Marshall sounds the same as the next :lol: Plus there are so many other things too.....His amp does...even these days...have something about it tho...
