Hmm, I've tried shielded cable too and no luck. Anytime I mess with a higher V1a/V1b cathode resistor (anything higher than 820) The gain drops, the noise drops, and so does the tone.fhn_lopes wrote:I did the one wire without the resistor, only with shielded cable. No hiss, lots of gain. I also tried a 10k at v1b cathode and it sounded KILLER, no thin sound or anything... again no hiss. Came it back to stock now but kinda regret it![]()
I'm just perplexed that other people's amps don't reflect the noise issue as bad as mine. I'll investigate more this weekend...that's my only free time at the moment.Colossal wrote:you are hearing the sound of the stream of electrons boiling off the filament and slamming into the anode.
Hiss noticeable at higher to very high volumes with high gain amps is normal. It is can be reduced to some degree depending on tube characteristics such as long or short plate and tube choice, but it is not going to be eliminated. Also, your perception of your amp being extra hissy might be due to differences in recording versus what you've heard posted. Even through an iPad, your amp sounded chewy and fat. Unless you notice bizarre artifacts trying to choke out the tone, which may be indicative of oscillation or other issues, it is probably fine. As mentioned previously, any efforts to reduce lead length and observe proper dress will help with the noise floor up to a point. I avoid shielded cable whenever possible.metalhead3ecr wrote:I'm just perplexed that other people's amps don't reflect the noise issue as bad as mine. I'll investigate more this weekend...that's my only free time at the moment.
