Rockstah mod6 Last circuit Design
topsportsmanta1
Post by topsportsmanta1 » Mon Nov 30, 2015 7:51 pm
ok so here are a couple clips from my rockstah mod 6 , this was what mark was working on , he had it all figured out , the tone stays no matter what volume its at and it is amazing , this is first time recording so i am not that good at it but let me know what yah guys think ,
https://soundcloud.com/topsportsmanta1- ... 2r/s-oSLuy
https://soundcloud.com/topsportsmanta1- ... -1/s-XdQmP
Last edited by topsportsmanta1 on Tue Dec 01, 2015 5:20 pm, edited 2 times in total.
mike
STEINBERGER
Re: Rockstah mod6
Post by STEINBERGER » Tue Dec 01, 2015 6:05 am
Is this an amp mark modded? was modifying?
What model amp?
btw 2nd clip sounds better. I suspect the recording technique could have been better. Good luck with your quest and i hope the amp gives you pleasure.
Sean_McFly
Re: Rockstah mod6
Post by Sean_McFly » Tue Dec 01, 2015 1:34 pm
Nice clips dude! I can't tell if Mark's mod6 sounds more like a plexi or a 2203 in terms of bass response and "sag" factor. Which does it sound like more in person?
"Guess you guys aren't ready for that yet, but your kids are gonna love it"- Marty Mcfly
topsportsmanta1
Re: Rockstah mod6 Last circuit Design
Post by topsportsmanta1 » Wed Dec 02, 2015 8:32 pm
Sean it sounds like a plexi , actually sounds just like your mod 5 but it retains that same tone no matter were you put the volume this circuit doesn't need a ppmv like the mod 5 .Mark had figured this circuit out and it is amazing, It has tons of gain on tap if you want it as my recordings show lol
My clips i had everything set wrong on the amp for evh toneI have never recorded before and i even had mic placement in the wrong spot , i am going to do some new clips set correctly with and with out a variac , the variac at 85 volts makes it warmer and even spongier , I just gotta figure out how to record it like it sounds in person ,I think i need a good software to record i am using audacity but here is my signal
guitar into mod 6
mod 6 into old Marshall 4x12 with old pre rola 20 watt green backs
sure sm57 into a pa out of pa to a cheap behinger sc 202 into my laptop
guys if you have suggestions for new stuff let me know as i am new to trying to record ,
thanks , tops
mike
