videocat23 wrote: The more solder you use, the more it will stay on, but it will also take a lot longer time to harden.
Not to be a prick... but this isn't correct...
"The Bigger the Blob, the better the job" in not true. it can cause the solder to cool unevenly and form a cold (weak) solder joint where you can't see it.
You need enough solder to secure the buss wire, or anything you are soldering, to the back of the pot, but it is better if you can still see the outline of the wire through the solder after it cools.
This is true for any soldering, even when you tin the twisted wire, you want to be able to see the individual wires in the solder.
