The amp is DONE!!!!! WHOO HOO!!!
cole
Post by cole » Mon Jun 09, 2008 9:37 am
I edited the above for the noted correction - thanks.
Les Paul Classic, Les Paul Standard Faded, Fender American Strat
Jackson Custom Shop Strat s/n 1226
JMP 2203, JCM 800 2205, Metro JTM 45
Metropoulos '68 12 Series s/n 12026
Marshall 1960 A/B 4 X 12's
chubs
Post by chubs » Mon Jun 09, 2008 3:22 pm
is that brass he soldered with...?
cole
Post by cole » Mon Jun 09, 2008 3:33 pm
Nah...it's just the color of paint he used to replicate what they did with old Marshalls but he's using a bronze/gold shade instead of red (red is what you'd see in 60's Marshalls on the solder joins)...it's probably Glyptal in gold color or something similar.
I really don't like it too much...hides the detail.
chubs
Post by chubs » Mon Jun 09, 2008 3:36 pm
So what was the spacing on your turret board holes? I did on with 1cm squrare and only get 6 holes per colum
cole
Post by cole » Mon Jun 09, 2008 4:35 pm
3/8" on center from hole to hole.
Froumy
Post by Froumy » Mon Jun 09, 2008 4:58 pm
Wow! Clean, beautiful build! I just looked at it for the 3rd time. That settles it, I'm never showing pics of mine. :oops: . Good inspiration for the next one. Nice work! Love that board, too.
Krinkle
Post by Krinkle » Tue Jun 10, 2008 1:37 pm
Just beautiful Cole. Your Brother owes you one.
Thanks for the Udo tip, I didn't know that.
Darrin
chubs
Post by chubs » Tue Jun 10, 2008 2:10 pm
For those curious, this is what he means by flying resistor
http://www.ceriatone.com/images/layoutP ... iatone.jpg
cole
Post by cole » Wed Jun 11, 2008 8:19 pm
One last photo...after I finally installed a logo...
Cheers :D !
Cole
Lucid7
Location: Cincinnati ...15 years and I still can't find WKRP
Post by Lucid7 » Fri Jun 13, 2008 10:01 am
Holy Cats! Beautiful work! Nice Job!
Darren Hopkins
Cincinnati, Ohio - Amps, Strats, Cats & Beer
cole
Post by cole » Fri Jun 13, 2008 11:23 am
Thanks Darren!
I've gotten the bug again for more builds..
My next will be very soon I hope. :)
cole
Post by cole » Fri Jun 13, 2008 3:31 pm
Just wanted to make a few notes/tips on the build:
Soldering:
I use smaller diameter Kester 60/40 on almost all connections except on the tube sockets where I use standard size solder, which requires just a dab on a hot joint and makes it easier to solder in vertical positions without it running over all creation and making a messy connection.
I use a 35 watt Weller and keep a very wet cloth (not paper towel) nearby to clean the iron's tip just before I work on a join/connection. I use a small chiseltip tip and replace after each build. Get a holder for the iron - it's a must.
Amp Cradle:
An amp cradle is essential - no one who does a build once without one will do a second build without it. make one out of a bit of plywood and some strapping.
Masking:
Mask off the front and rear panels with green or blue masking tape to prevent anything from happening such as dropping a soldering iron onto them, solder flux, etc. Also they have sharp corners and it's less a chance you'll get snagged. Ouch!
Straightening Component Leads:
Use some hardwood or an aluminum carpenter's square (something hard and flat) against a hardwood cutting board (used as a base) and let the component body sit just outside the edge of the board while 'rolling' the component lead straight using short strokes. Repeat for the other end of the component. You'll get dead nuts straight leads which improve the look of the build.
Ricky Lee
Post by Ricky Lee » Fri Jun 13, 2008 3:51 pm
1+
Ricky Lee
Post by Ricky Lee » Fri Jun 13, 2008 3:52 pm
1+
chubs
Post by chubs » Mon Jun 16, 2008 7:54 am
GREAT advice on the rolling leads to get the straight... I never though of that... THANKS!!!
