Well both ways will perform the same as long as you used the samed size bus I guess. I doubt some one with dog hearing could hear the difference.rockstah wrote:Mike, im not much into looks myself - more about performance for me. but i can understand it for people who are.
i wonder if the have the pots drifted any with all this heat on them?
I can check some to see how much they drifted. If they did, it would only be slightly upwards; probably by the same percentage as the Allen Bradley CC, that according to the spec sheet on page 5 of my Art of electronics book, says +/- 2%. with 300 degrees Celicius at 1/8" inch away.
I say no more than +2%, cause I've never seen a CC drift down with heat, and I drift some CC's intentionaly like my 820s. But I do to doses of 30 seconds, at 850 degrees F, at 1/8" away, to make a 820 that reads 950 Ohm into a 1.1k.
You can only drift them so far.
I can get an 820 into the 900s,
But then again that's 2 doses of 30 seconds a 850.
I'm only applying heat for 4 to 5 seconds on my pots, and it's to the outer casing.
I'll check and get back, but I wish I had wrote down what they were before.
I'll do a before and after on the next one.
But the amp in my signature has those kind of pots, soldered that way, and sounds good (imo) and Chris ****** does them that way, so you know it can't be all bad.
Like I said, it's not for everyone.
I'm not saying my way is better.
But I like it better.
