0.68μF 600v Any good?
Posted: Thu Mar 06, 2014 10:46 am
by JimiJames
Curious what composite are these ? Poly? Could I use them like the 160v Mustard? What to expect?
Re: 0.68μF 600v Any good?
Posted: Mon Mar 10, 2014 1:44 am
by JimiJames
anybody ? :shock:
Posted: Mon Mar 10, 2014 12:20 pm
by danman
If you are planning to use it as a cathode bypass cap like in a Marshall circuit you will be fine. There isn't alot of voltage there on the cathode.
Posted: Tue Mar 11, 2014 4:54 pm
by ezs
Posted: Tue Mar 18, 2014 6:03 am
by JimiJames
most kool !
thanks for the leg work on that. 8)
danman wrote:If you are planning to use it as a cathode bypass cap like in a Marshall circuit you will be fine. There isn't alot of voltage there on the cathode.
These would be for a frankenbuild and just wanted to know if these could be used in a pinch; and I see if it meets the ratings it should work just fine....
Yes... I see that the Mustard's are 160v and I was curious if the higher voltage rating had an effect.
As long as it's 160v or more seems to be A.O.K.
~Jimmie
Posted: Mon May 19, 2014 10:52 pm
by emmjaydubya
Found these a while back if you're interested, I've dealt with the seller several times. Not the cheapest caps but proven to sound great:
http://www.ebay.co.uk/itm/1x-NOS-WIMA-T ... 232d2cb366
Posted: Tue Jul 22, 2014 10:09 am
by Skippy
Out of interest... can a 120v .68 mustard be used as a cathode bypass cap or does it need to be 160v min?
Posted: Tue Jul 22, 2014 10:59 am
Skippy wrote:Out of interest... can a 120v .68 mustard be used as a cathode bypass cap or does it need to be 160v min?
It'll be fine - no voltage to mention on the preamp cathodes
Posted: Sat Jul 26, 2014 4:28 pm
by Carbia
Yes, the cathode voltage there is around 1 or 2 volts. Every cap can be used
Posted: Sun Aug 24, 2014 4:57 pm
by demonufo
As for the 600V, whilst it will be fine, the higher voltage rating may make a very appreciable difference in that position. A 600V cap will have a massively higher Equivalent Series Resistance over a 160V cap, which will almost certainly make an appreciable difference on this particular cathode where only a few volts are present, in operation at least. Whether or not it is for the better or worse is all personal preference though. The difference in ESR however may not even be particularly perceivable to the ear, as cathode cap types seem to have a far lesser effect than the couplers.
Posted: Tue Sep 02, 2014 6:49 am
by Haze13
Caps that worth spending money on are: 22nf in the Pre and Pi sections; 100nf that connected to the grid of the PI tube from the Negative Feedback. Others can be any thing you want, but with good tolerance and long life => less electrolytics as you can.
Posted: Tue Sep 23, 2014 1:53 pm
by Joshabr1
demonufo wrote:As for the 600V, whilst it will be fine, the higher voltage rating may make a very appreciable difference in that position. A 600V cap will have a massively higher Equivalent Series Resistance over a 160V cap, which will almost certainly make an appreciable difference on this particular cathode where only a few volts are present, in operation at least. Whether or not it is for the better or worse is all personal preference though. The difference in ESR however may not even be particularly perceivable to the ear, as cathode cap types seem to have a far lesser effect than the couplers.
W
Very true. Great point.
