RECTIFIER VOLTAGE PROBLEM on a JTM45 RI with HW board ?
- Flames1950
okaaay, i fired it up and played; it works !
it sure sounds better than the stock ri but i wonder if the marstran was the way to go !
on top of that , knowing that HEYBOER REVERSED THE COLORS OF MY OT PRIMARY , i'm not happy to have lost so much time on that.
i didn't make any mistakle in reality, just a stock reversed PRIM OT (or the one that JTM100 mounted was reversed but i'd say mine is) and a bad rectifier tube !!!
a chance i didn't start to unsolder all around in the amp but i knew my wiring was good and solders as well.
the more i listen to the dagnall clone compare to the original 70' one and to the MM100 in the clips that georges recorded, the more i prefer the MM for its rich mids.
i bought a dagnall clone from georges last spring as well as one from ****** (are they heyboer as well ?) to rebuild my 95' 1959SLP but i found an original 72' just after so i will use this one but i will try to take the time to compare them.
does anybody know how the jt45MM OT compares to the other clones and to the original, i haven't heard any clips ?
hey JTM100, how did you like the amp you mounted for your friend steve ?
was the sound great ?
i think i prefer my original marshall 50 & 100w's but it's not exactly the same amp, though my 65' JTM100 isn't that far.
i tried it with a g12m25 ri 4 12.
i will try it better and with other guitars as well.
the lower filtering makes me feel like it's closer to some older gears as well, making the sound looser; less stiff.
that's a common fact i noticed on old gears compares to newer ones.
- Flames1950
