Bypass cap question
Bypass cap question
On the '68 100 watt SuperLead board, what is the value of the electrolytic bypass cap on the cathode of the first stage of valve 2 (pin 3)? Most amps I see have a .68uF cap here.
- VelvetGeorge
- Site Owner
The only other common (not that common though) Marshall value I know of there is 330uF. Thats the supposed value in the EVH Holy Grail amp. Ive always had the stage 2 Ck on a switch to take it in and out. I mostly used .68 but I tried the 330u and its a interesting sound in its own right. Its inspired me to use an on/off/on minitoggle in my newest 100W project to switch between no bypass and those 2 values though Ive read posts were people do things like put a 5 way rotary switch in there and go through more values. Usually .68uF wouldnt be an e-cap.
Just an update............
I tried the 330uF cap and I am very pleased with the tone. The cap has brought a little more focus to the midrange (but not making it over pronounced). The amp still has a great open growl, but I feel that it now sits better in the mix of a full group. Its similar to adding light compression to the channel at the mixing desk, but I get it onstage (without relying on monitors).
For reference sake, this is a split cathode design with the channels bridged (50-watt).
