I have a killer OT coming from M****N, who may be persona non grata here, not sure exactly what the story is. It is a copy of the original OT when it comes to materials and build style but with the power and primary impedance matched for 2 KT88's instead of 4, and the UL taps at the correct percentage as the original (33%), as opposed to the Mercury Magnetics OT (12%) some people have used for their mini major (not the 200W MM replacement). Also, from what he tells me he has determined how to build it so it will not fail. I am assuming he means as long as I don't do anything stupid.
Which brings me here;
I will be using a Metroamp laydown PT that I pulled from my Metroamp build. This will put my B+ at about 485VDC. From poking around the net I see a bunch of info/opinions. I'd like to determine the best possible value for the screen resistors, not just default and put one as big as a truck in there. So I'm asking for some help in figuring this out.
If my plate/B+ voltage is at 485VDC, will there be times when the screen voltage is very close in value. If so, is this too high for modern KT88's (I have a matched set of JJ's)?
Does anybody here know the application and math well enough to just give me a simple answer?
I'll leave it at that for now as I've already been too long winded. Here are some shots of the build so far for anybody who scrolled down this far
http://s793.photobucket.com/user/Darrin ... sort=3&o=3
http://s793.photobucket.com/user/Darrin ... sort=3&o=2
http://s793.photobucket.com/user/Darrin ... sort=3&o=1
http://s793.photobucket.com/user/Darrin ... sort=3&o=0
