hello i just finished a jtm45 clone useing jtm45 upgrade kit and
heyborer transformers from metro amp. sounds great in fact
its a great deal louder that i thought my question is what is the
expected wattage of this amp? i am running threw a 1960a
cab w 75ers
thanks jimmy
jtm 45 wattage
- dad99_2000
- Flames1950
Mine runs at 39 watts clean, biased with a slight crossover notch and with a weber copper cap (GZ34-type) as a rectifier. Technically, this acts the same as a tube rectifier. Then again, I do have 50w plexi power and output trannies, as well as EL34's, but a JTM45 board. Try taking out the tube rectifier and soldering diodes across the rectifier socket. See how much you get out of it. You'll probably be able to milk 45 clean watts.
