What capactor's and resistor's should I use for my high gain
Marshall build I want to do.
This amp will have a switchable 39k cold clipper along with jose master and diodes. Go from bright side of a super lead to an 800 and above.
Any thoughts or sugestions would be great!
Thank you,
Jason
Thank you,
Jason
Re: What capactor's and resistor's should I use for my high gain
I like sozo,s and carbon film but I dont know squat there just easy high quality and quite . What does your layout look like, sounds like a good idea for a high gain amp. Bill
One watt 500v rated CF resistors from Mouser and non-metalized polyester film/foil caps such as the 225P or PS series or Mallory PVC series Orange drops or standard SOZOs if you need axials. It doesn't hurt to use polypropylene in the phase inverter in some cases but use a Mica for the fizz cap. I like ceramics for low value bypass in the signal path like the 470p in the tone stack and the 470p/470K in Marshalls.
The longer the signal path, the less it matters as long as you use decent quality stuff such as the cheap Xicon metalized polypros. Once you get past 3 gain stages with a lot of attenuation between stages it is hard to hear any component type differences.
On one end you have Trainwrecks where the damn color of the wire affects the tone and on the other, a 5150 with six stages.
..Joe L
..Joe L
- kdmay
Has anyone used these resistors? (Go to Parts, Resistors)
http://www.westlabs.com/Frames.HTML" onclick="window.open(this.href);return false;
Metal film 1% 1 watt, the specs seem impressive but the price is to match! That said, in a plexi it's a $28 difference, so not too bad.....
- jerrydyer
never heard of em...
vids.
- demonufo
Probably sound fantastic in hi-gain solid state headphone amps.
No idea though to be fair.
For what it's worth, I have spent MUCH more than that on resistors before (now out of manufacture Riken Ohms, some of which were $6 each) and no, I definitely did not get anything like my "money's worth". They're not bad however, but I really wouldn't recommend them at the price. Partly since many values are now damned near impossible to find.
Kiwames are very popular for real high quality Carbon Films these days (also identical resistors under the Koa Speer brand which are cheaper. However, I don't know WHICH model of Koa Speer is the same as the Kiwames).
Metal Films generally don't float my boat in guitar amps, but some of the low-noise Vishay types are a definite "neutrality" improvement in many hi-fi builds that I used to mess around with in the not-so-distant past.
![Laughing :lol:](./images/smilies/icon_lol.gif)
So I like purple, okay!!!!!!
- kdmay
Hmmm, I have one of those on my list, maybe I should try them out!!demonufo wrote:Probably sound fantastic in hi-gain solid state headphone amps.![]()
![Listening :listen:](./images/smilies/headphones.gif)
Those Kiwames look interesting. Around the same price and you can get 2w and 5w versions, so presumably they could work in the B+ line too.demonufo wrote:For what it's worth, I have spent MUCH more than that on resistors before (now out of manufacture Riken Ohms, some of which were $6 each) and no, I definitely did not get anything like my "money's worth". They're not bad however, but I really wouldn't recommend them at the price. Partly since many values are now damned near impossible to find.
I had a post a while back. Searching is your friend
http://forum.metroamp.com/viewtopic.php ... &sk=t&sd=a
Rip
Rip
- Doug H
I ended up sold on the amtrans resistors. I excperimented with switching them in and out of the plate on V1 and am convinced it made a difference. To me they are a bit smoother than typical and classic cf but had a solid feel to them.
Theere's a multitude of tests I haven't done that occur to me, like .5w versus. A lot of modern half watts are spec'd at 350 volts or so, so maybe part of the old NOS voodoo is the resistors could handle more voltage without colouring the sound? So maybe any quality 1w resistor will be tops? Or the opposite, a stressed resistor running over spec adds that magic mojo. It probably depends what kind of tone you are after.
When I put an old 100k piher in to me it moved the tone towards that old school sound, lots of bark, open and firm sounding with some top end sizzle. Cheap cf I tried sounded similar but didn't have the same mid range bark, some other brand was more compressed, not as firm, the amtrans sounded most the same but wuith less sizzle.
Ti my ear and IMO...mystic voodoo bs? maybe I gear things that aren't there? I did come up to my amp a few times and without knowing which way the switch was on the back, played a bit and guessed right almost all the time.
If you want something tried & true that's going to last for decades, I'd stick with Vishay Metal Oxide's, Ohmite power & orange drop coupling cap's. the best sounding amp's throughout the many years of great tone and players are base-lined with these products. it sounds like from your description you are building a 2ch amp with a dirty & dirtier ch select. maybe the 2ch plexi style amp I posted in the tech section might be something to consider. here's a look at the schematic. alot of room left for modern tweaks if the need is there, however the level & balance of tone and gain are abundant. I can post clips if you have an interest after viewing the schematic.
wishing a Happy NewYear to you all!
Dennis
Dennis
- (80.23 KiB) Downloaded 2463 times
Sorry to drag up an old topic but I was doing research and this spoke to me. Hopefully some of y'alls experience can help me out here:Doug H wrote:I ended up sold on the amtrans resistors. I excperimented with switching them in and out of the plate on V1 and am convinced it made a difference. To me they are a bit smoother than typical and classic cf but had a solid feel to them.
I've got a Ceriatone 1987 clone that I've hot-rodded into something like a Bray-style amp. I've done all the experimenting I want with capacitors, now I'm looking at resistors. The amp came with carbon comps, but it's not Allen Bradleys, I'm pretty sure. With caps, I gravitate away from darker caps like Sozos, to more open caps like CDE DME series. So I was going to experiment with plate resistors first. I think the mixer resistors and input resistors would also be good candidates since signal actually passes through them.
Basically, I like my tone but I'd like it to be a bit more "open" and hear the nuances of the guitar and strings, but not at the expense of it sounding harsh or fizzy.
Partsconnexion has a lot of different resistors. I got the resistors for my last build from them. I used the pink Takman CFs for all the 1/2 watt resistors except for the preamp plates where i used Arcol CCs.
- Doug H
I think a lot of modern high end resistors are made with beoing in the audio9 path in mind, not so much being on the plate of a high voltage tube. You have to wonder what the "stabillity" was in the old high stabillity resistors.
I'm particular about caps, but resistors to me don't make a big difference. I use carbon film for the signal path and metal oxide for power supply. I've tried others in the signal path including carbon comp and to me it just doesn't make much difference, and what difference i did note wasn't to my ear as good as carbon film.
Now caps DO make a considerable difference to my ear at least. Sozos are great and can really make the tone thicker and richer harmonically, but the fact is theres a time and place for everything and if you really spend the time to try different caps in different locations you may find what i did. that would be that as good as sozos are i prefer mallory or other *lesser* caps in some locations, especially the tonestack. Your best bet is to try a lot of stuff and see what works for you. But a lot of swapping back and fourth is required for you ear to truly start to hear the difference clearly enough to know what works.
Dior Jordan 1
Balenciaga Outlet
Moncler Outlet
Pandora Jewelry
Jordan 1 Retro
Pandora Jewelry
Adidas Sale
Pandora Charms
Wholesale Jordan
Pandora Jewelry
Moncler Jackets
Moncler Coat Women
Pandora Jewelry Official Site
Pandora Official Site
NMD R1
Balenciaga Shoes
Pandora Outlet
Pandora Rings
Nike Outlet
Women Nike Shoes
Pandora
Pandora
Jordan Retro 1
Yeezy
Pandora Charms
Nike Mens Shoes
Nike Shoes
Nike Store
Pandora Outlet
Balenciaga
Nike
Adidas Shoes Men
Nike Air Jordan 1 Retro
Balenciaga Triple S
Pandora Bracelet
Adidas Canada
Pandora Charms
Air Jordan 1 Retro
Pandora Charms
Yeezy Boost 350 V2
Pandora Charms
Asics Gel-Kayano
Nike Store
Adidas
Nike Outlet Store
Nike
New Nike Shoes
Pandora Charms
Pandora Charms Sale Clearance
Nike Outlet Online
Pandora Jewelry
Goyard Bag
Moncler
Pandora Charms Outlet
Goyard Handbags
Moncler Coats
Air Jordans 1
Pandora Jewelry
Adidas Running Shoes For Men
Nike Shoes
Moncler Jacket
Nike Shoes Women
Moncler Outlet
Pandora Jewellery
Ferragamo Shoes Women
Pandora
Adidas Official Site
Adidas Shoes
Asics Outlet
Pandora Bracelets
Adidas Sneakers For Women
Pandora Outlet
Nike Shoes For Men
Air Max 720
Pandora Charms
Asics Shoes
Puma Shoes
Wholesale Jordan
Nike Shoes
Pandora Outlet
Pandora Jewelry
Cheap Moncler
Balenciaga Sneakers
Asics Running Shoes For Women
Pandora Jewelry
Nike Canada Online Shopping
Pandora
Nike
Adidas Shoes Women
Ferragamo Belt
Pandora Bracelet
Asics Shoes
Moncler Sale
Nike Store
Pandora Bracelet Charms
Jordan 1 High
Wholesale Jordan
Pandora Jewelry
Jordan 1s
Asics Sneakers For Women
Pandora Charms
Adidas Yeezy Canada
Balenciaga Shoes Women
Pandora Outlet
Jordan Ones
Basketball Shoes
Jordans Wholesale
Jewelry Pandora
Balenciagas
Outlet Asics
Ferragamo Belt
Shoes Adidas
Nike Sneakers Women
Adidas Trainers
Nike Outlet Store
Pandora Ring
Salvatore Ferragamo Belt
Pandora Jewelry
Nike Shoes Women
Pandora Charms
Jordan 1 Lows
Nike Running Shoes Sale
Nike Shoes Outlet Online
Pandora Charms
Nike Sneakers For Men
Air Jordan 1
Pandora Bracelet
Cheap Adidas
Pandora Jewelry
Jordan 1
Pandora Charms
Adidas Shoes
Jordan 1 Low
Pandora Outlet
Adidas Outlet
Nike Canada
Pandora Jewelry
Yeezy
Nike Snkrs Canada
Balenciaga Outlet
Moncler Outlet
Pandora Jewelry
Jordan 1 Retro
Pandora Jewelry
Adidas Sale
Pandora Charms
Wholesale Jordan
Pandora Jewelry
Moncler Jackets
Moncler Coat Women
NMD R1
Balenciaga Shoes
Pandora Outlet
Pandora Rings
Nike Outlet
Women Nike Shoes
Pandora
Pandora
Jordan Retro 1
Yeezy
Pandora Charms
Nike Mens Shoes
Nike Shoes
Nike Store
Pandora Outlet
Balenciaga
Nike
Adidas Shoes Men
Balenciaga Triple S
Pandora Bracelet
Adidas Canada
Pandora Charms
Air Jordan 1 Retro
Pandora Charms
Yeezy Boost 350 V2
Pandora Charms
Asics Gel-Kayano
Nike Store
Adidas
Nike Outlet Store
Nike
New Nike Shoes
Pandora Charms
Nike Outlet Online
Pandora Jewelry
Goyard Bag
Moncler
Goyard Handbags
Moncler Coats
Air Jordans 1
Pandora Jewelry
Nike Shoes
Moncler Jacket
Nike Shoes Women
Moncler Outlet
Pandora Jewellery
Pandora
Adidas Shoes
Asics Outlet
Pandora Bracelets
Pandora Outlet
Nike Shoes For Men
Air Max 720
Pandora Charms
Asics Shoes
Puma Shoes
Wholesale Jordan
Nike Shoes
Pandora Outlet
Pandora Jewelry
Cheap Moncler
Balenciaga Sneakers
Pandora Jewelry
Pandora
Nike
Adidas Shoes Women
Ferragamo Belt
Pandora Bracelet
Asics Shoes
Moncler Sale
Nike Store
Jordan 1 High
Wholesale Jordan
Pandora Jewelry
Jordan 1s
Pandora Charms
Adidas Yeezy Canada
Pandora Outlet
Jordan Ones
Basketball Shoes
Jordans Wholesale
Jewelry Pandora
Balenciagas
Outlet Asics
Ferragamo Belt
Shoes Adidas
Nike Sneakers Women
Adidas Trainers
Nike Outlet Store
Pandora Ring
Pandora Jewelry
Nike Shoes Women
Pandora Charms
Jordan 1 Lows
Pandora Charms
Air Jordan 1
Pandora Bracelet
Cheap Adidas
Pandora Jewelry
Jordan 1
Pandora Charms
Adidas Shoes
Jordan 1 Low
Pandora Outlet
Adidas Outlet
Nike Canada
Pandora Jewelry
Yeezy
Nike Snkrs Canada
