The reason that there will be minor differences to the instructions in my build, is that I´m using the laydown mount 1203-80-ML PT - as opposed to the stand up version used in the instructions. This calls for different wire dress. In addition to that, it was recommended to me in another thread to change the power switch wiring, to make the amp a bit safer. My altered power switch wiring is modeled after a TAD SL kit layout. And to improve on the stock grounding, I decided to implement SDM grounding on my amp. All of this was discussed in separate threads, which can be found here:
http://forum.metroamp.com/viewtopic.php?f=7&t=41152" onclick="window.open(this.href);return false;
http://forum.metroamp.com/viewtopic.php?f=7&t=41095" onclick="window.open(this.href);return false;
http://forum.metroamp.com/viewtopic.php?f=7&t=41814" onclick="window.open(this.href);return false;
So far, I finished fitting all the main components to the chassis. Today, I´ll start soldering. This build might take a bit long to finish, since I have a lot of other stuff on my mind lately. But I surely will reach my destination in the end.
Chassis is the 1969 steel chassis from Valvestorm, trannys from Heyboer, board from Brian H, NOS mustards - let´s get the party started.
First pictures:
