I've just finished this amp (schem attached) couple months ago and everything was going fine until last two weeks when I started to notice that when I dial both gain and volume controls to the max I got some volume drops when I pluck bassy notes. It's like a very low frequency tremolo effect but just when I pluck hard mostly the low strings. It's like the power section is going to a cut off region.. the volume drops quite noticeably. I got some hum noise (at quite acceptable levels, I'm not complaining about it) on it.. so when it happens even the hum noise goes away and then comes back in less than a second. It follows the volume drop.
When checking with the DMM the power supply, I have these idle voltages:(A) 396v, (B) 370v, (C) 330v, (D) 300v.
When playing, the (B), (C) and (D) voltages drop a lot. (B) and (C) drops about 50v. (D) drops about 25-30v. Is that normal?
I've got 23v across the V3's pin 8 to ground. I swapped the 470R cathode resistor to a 560R in order to get more power section saturation. According to my math, V3 is draining around 41mA (idle).
For that scenario, I assume that the plate is dissipating about 14w (not overall power, but the plate dissipation.. which is acceptable, according to the JJ 6v6s datasheet), right?
Well, no red plate. Everything works fine.. until I crank the amp.
Does anybody here have idea what's going on with this guy?
Any help will be much appreciated.
Thanks in advance.
