I find a guy here to make me a kind of Bogner 101B (pre-2004) clone but with 6V6 power section.
What I wanted is 2 channel:
-First channel is the Plexi mod
-Second channel is the Red channel (but switchable to blue)...
After the amp was made, I had to change some stuff in it. I removed the boost (it was hard wired), removed the post-2004 gain boost. I want the amp to be the nearest of the original 101B (and yes I like the chewie dark sound)...
The result work well but I have two small problem, any help would be welcome:
-The Plexi channel has less volume than the Red/Blue channel. On the original 101B, I don't have this problem...
-The Red/Blue channel seems to have a little bit too much gain and being a little bit on the fizzy side compare to the 101B.
Here is a schematic I made of the amp, if someone could check it, it would be great! Any suggestion are welcomed!
https://www.dropbox.com/s/wzd46y8pt2o1a ... d.pdf?dl=0
I know I have to replace the Treble pot for a log one to get more in the ballpark of the original.
I would compare with the original amp, but I do not have it on hand right now...
