RockinRocket
Post
by RockinRocket » Wed Jul 24, 2019 11:34 pm
wombat wrote: ↑Wed Jul 24, 2019 8:13 pm
RockinRocket wrote: ↑Tue Jul 23, 2019 9:02 pm
The whale tufnol is crap.. wonder if the carp is any good wombat?
Whale grade Tufnol is only recommended as electrical insulation in low voltage environments.
Carp grade has better electrical insulation properties due to it's finer weave (not as good as paper phenolic though). To my eyes it's finer than the weave Marshall used in their own fabric laminate boards back in the day. In practice I've been running this amp for 5 months with no issues whatsoever.
That being said, if you are concerned about moisture absorption then you should probably use something else.
Low voltage means diferent thing in different country's but in the UK low votage is good up to 900VDC.
All I konw for certain is the brown board and cream board Marshall used in the 70 dont have any small mA leakage in the amps I own.
Post
by Roe » Thu Jul 25, 2019 3:48 am
very nice build I must say. I personally like 50+50uf on the screens and phase inverter - it just gives that classical sound and response we've heard on so many records. I even like smaller screen resistors on low voltage amps. 1k takes avay some aggression on these amps, as does low preamp voltages. Finally, a switchable 5nf/100pf bright cap is a great idea (although switchable 2204 is not bad either). CTS makes a large 1ma pot with push-pull switching but they are expensive
wombat
Post
by wombat » Mon Jul 29, 2019 1:43 am
That's the cool thing about JMP 50s - there's a fairly broad spectrum of components and specifications that you can choose from depending on taste.
The specifications I chose were a matter of personal preference for me. The amp has a healthy amount of gain (more than I was expecting) but at the same time, it is quite pleasing on the ears and not too harsh. I can listen to it all day long without getting ear-fatigue and I guess that's the quality I like about it the most.
I think that the specs that I went with (including the lower filtering etc) went a long way to giving the amp it's "velvety" nature. Those specs got it almost there, but I also had to audition a lot of pre amp and power tubes before it went that little extra step where I was completely happy with it.
Post
by neikeel » Fri Aug 30, 2019 4:54 pm
Sorry I missed this.
Lovely build, not surprised that it sounds good, hopefully played enough now that it is fully bedded in?
wombat
Post
by wombat » Sun Sep 08, 2019 11:59 pm
Thanks Neil!
Yes, it has bedded in nicely. I haven't developed any urges to tweak it which is always a good sign
Anderson1987x
Post
by Anderson1987x » Thu Oct 24, 2019 2:00 am
That's such a beautiful build Wombat, any advice for a nebwie looking to one day make such a great looking unit? I really hate to ask this but do you build amps for a living/business or is it just for fun and the passion?
Such a great looking amp, bet it sounds just as good
axeman
Post
by axeman » Thu Nov 14, 2019 11:45 am
I have a lot of the Whale boards and used it in a few builds with no problem. I can see it being a problem if you live in area with constant high humidity, but here in California I don't worry about that.
https://www.youtube.com/watch?v=uafbNOg1OJ4&t=1s
