updating my Mom's Compaq ???
Post by VelvetGeorge » Wed Oct 25, 2006 4:04 pm
My Mom has a Compaq computer with Windows ME that just sucks. She has all kinds of trouble with it. I tried to update to XP Pro (with a legit disk) and it says the serial number is incorrect. Does Compaq require that you get upgrades directly from them or something???
What's the work around for this? Aside from wiping the drive and installing from scratch?
Thanks,
rockstah
Re: updating my Mom's Compaq ???
Post by rockstah » Wed Oct 25, 2006 4:11 pm
VelvetGeorge wrote:My Mom has a Compaq computer with Windows ME that just sucks. She has all kinds of trouble with it. I tried to update to XP Pro (with a legit disk) and it says the serial number is incorrect. Does Compaq require that you get upgrades directly from them or something???
Thanks,
1. check to make sure u have the right serial number? and can u even upgrade from me to xp?
2. my advice, if u werent trying to avoid it in the first place, is clean install xp pro - u will have less problems this way.
Mark
Post by VelvetGeorge » Wed Oct 25, 2006 4:25 pm
Do I need to use the serial from her comp?
I agree with you. I may just wait until the semester ends (she's in college right now) and install XP from scratch.
ME is stupid crappy. She can barely finish her classwork on this heap.
VG
rockstah
Post by rockstah » Wed Oct 25, 2006 4:39 pm
VelvetGeorge wrote:Do I need to use the serial from her comp?
VG
im not real sure if u need her reg # to validate or not. just wait and do the upgrade right. ;) clean install baby!
45auto
Post by 45auto » Wed Oct 25, 2006 5:19 pm
my mom had that same rig. she never had any probs for the longest time (years) clean install for sure. there's nothing like a clean format. serial should work.
rockstah
Post by rockstah » Wed Oct 25, 2006 5:20 pm
oh and when u do reformat that drive do a low level format (it takes alittle longer )
St August
Post by St August » Wed Oct 25, 2006 7:12 pm
also there will be a 2nd partition for compaq crap make sure you delete that one as well....
and do it in NTFS
OnTheFritz
Post by OnTheFritz » Wed Oct 25, 2006 7:45 pm
Yeah, I'd delete the partitions, reset them, and XP will prompt you to then reformat, then it'll install. It should work out fine as long as the numbers that are with the XP are right.
