Insane Riffing
Post by yngwie308 » Mon Oct 23, 2006 10:21 pm
Found this Dimebag link on a Dean forum:
http://www.youtube.com/watch.php?v=5tNYICzSGVA
Ed's cool move to put the black/yellow Strat in the Kiss coffin.
RIP Darrell.
Yngwie308
Necrovore
Post by Necrovore » Mon Oct 23, 2006 11:18 pm
yngwie308 wrote:Found this Dimebag link on a Dean forum:
RIP Darrell.
Yngwie308
He could sure play. One thing I can never figure out is all these kids freaking out on all the squeals he does, like they are the hardest trick to do. Squeals are easy.
The two tricks I have never been able to master are the pick scrape(mine always sound weak as hell), and that effect you do when you trill on the fretboard and then move your picking hand towards your fretting hand, while using the side of your picking hand to hit the harmonics to create a wierd, glassy flanging effect(listen 3-4 seconds in on the first lead break in Slayer's Captor of Sin).
Bad Kitty
Post by Bad Kitty » Tue Oct 24, 2006 4:48 pm
The trick with the trill is to put the string that your trilling in the crease of your hand. That way there you mute the other strings while the trilled string is just lightly touched. I figured it out from watching a VH solo about 50 times. He did it on the top three strings in a row, one after the other.
As for the pick scrapes I've found that if you have less distortion it works better. And scrape from the D string to the low E.
Your milage my vary,
Mike
Never settle for an amp thats smaller then you are.
