Desolder braid or desolder pump
Herec
Post by Herec » Tue Feb 12, 2008 4:02 pm
Which one do you find is more effective? I've only had experience with desoldering braid.
gutpile
Post by gutpile » Tue Feb 12, 2008 4:13 pm
for me, Braid... hands down... could never get the hang of that damn solder sucker!! it never seems to fit right exactly where I need it to... maybe I'm just stupid...
ScottW
Post by ScottW » Tue Feb 12, 2008 4:30 pm
The sucker is way faster and almost always gets the job done for me. When it doesn't, I go with the braid to finish it up. The sucker is what I usually grab first....
Maschinenmann
Post by Maschinenmann » Tue Feb 12, 2008 4:37 pm
Braid for pcb stuff, sucker for tag board etc. Gotta have both! :wink:
User of the Wheel
HEAVIER THAN HELL
Post by HEAVIER THAN HELL » Tue Feb 12, 2008 5:19 pm
Maschinenmann wrote:Braid for pcb stuff, sucker for tag board etc. Gotta have both! :wink:
+1, thats exactly my take on it too.
Doug H
Post by Doug H » Tue Feb 12, 2008 5:29 pm
I don't have much luck with the braid. Maybe for cleaning up a PCB. I'd be lost without the sucker.
NitroLiq
Post by NitroLiq » Tue Feb 12, 2008 5:42 pm
I'll have to try one of those vucuum suckers....I tried using one of those cheap desoldering bulbs years ago but it was a joke...the solder wouldn't suck up quick enough or would harden on the bulb's tip....useless. I've used braid ever since without problem.
Sparky
Post by Sparky » Tue Feb 12, 2008 6:20 pm
Gotta have both!
Post by yngwie308 » Tue Feb 12, 2008 6:55 pm
Depending on the pcb lands or thickness a good sucker is worth two in the braid, unless it is a large component you are desoldering.
That's what i used to do for a living, but no more, won't catch me with a soldering iron, no, no, no.. :lol:
chad
Post by chad » Tue Feb 12, 2008 8:10 pm
Most definitely got to have both. Both comes in handy at different times. Chad
OnTheFritz
Post by OnTheFritz » Tue Feb 12, 2008 10:06 pm
I've got a desoldering iron and a bulb sucker.
I use the desoldering iron 99% of the time.
Never tried the braid, have to give that a whirl.
Post by Flames1950 » Tue Feb 12, 2008 11:05 pm
BRAID. Suckers, well, suck.......... :wink:
Billy Batz
Post by Billy Batz » Wed Feb 13, 2008 7:12 am
Funny my RS sucker works for me every time. It can get clogged often but its not a huge problem just a slight annoyance but heat the turret, put the sucker on it when I see the solder start flowing, and its empty a second later.
planetjimi
Post by planetjimi » Wed Feb 13, 2008 10:03 am
You need both. If you can get the tip of the sucker in there (like a turret) the sucker is perfect. but other places like a tube socket with all that crap in the way sometimes you can only squeeze in there with a some braid.
Guitar-Sam
Location: Various venues earning money to pay off gear LOL
Post by Guitar-Sam » Fri Feb 15, 2008 2:58 am
So......I'm the only shoe maker that uses the "Heat it up and wack it on the table" method of solder removal?? :P 8)
74' Stratocaster
Several Frankenstrats
Orange Tiny Terror & PPC 1x12 cab
Marshall 2210
69' Marshall 4x12 "B" cab
Dean Markley CD-60
